5th gen grounding.
Old Jul 1, 2004 | 03:38 AM
Clay's Avatar
5th gen grounding.
I've got a new setup, and I've wired everything except a finalized location on for the gound wire. Anyone have any suggestions on a good location in the trunk? Closer to the rear the better. What I've come up with so far as options were the trunk latch area, or the spare tire area. I'm grounding a 4 gauge wire btw.
Old Jul 3, 2004 | 11:19 AM
Clay's Avatar
No ideas? Where have other people grounded to?
Old Jul 3, 2004 | 11:30 AM
slickrick's Avatar
i just drilled some screws into the trunk between the side wheel well and the spare tire well. i think i described the correct area.
Old Jul 4, 2004 | 07:57 AM
joebangaa's Avatar
I pulled back the carpet/covering behind the rear wheel well. There's good points there, really close so no need to use so much ground wire.
Old Jul 4, 2004 | 10:28 PM
WildmanAL's Avatar
I have my system grounded to up under the rear deck. My stereo grounds out and comes back on sometimes apon start up. I'm probably going to ground to the rear strut.
Old Jul 5, 2004 | 12:26 PM
Clay's Avatar
I ended up grounding it to the read trunk release. It works great... no noise. If anyone is interested I can post some pictures of it.
Old Jul 5, 2004 | 05:14 PM
MIXXMAX's Avatar
Anywhere on the trunk floor is fine. That is where I ground mine. It's good to sand/file the metal to a fine shine to get better connection and less noise.
Old Jul 5, 2004 | 06:07 PM
MiniRX7's Avatar
I just the bolt that holds the seats down. No drilling required
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
