Bad Radio Reception after installing aftermarket Head unit...
Is this something that normally happens? The radio that I put in never had these issues in the other car that it was installed in. Now that I put it in my Maxima, I don't get very good radio reception. Is this normal?
if it doesn't, like i said, you can tap that into the radio's acc. wire, meaning it'll turn on when you turn on the car.
The guy who installed the radio did the harness just like any other radio he's ever done. Is this separate power wire for the antenna anything different than any other car?
ok, well i don't know other cars, as every car i've owned has been a maxima, and all of THOSE are the same.
the antenna can be connected, but you need to turn on the antenna motor.
we dotn' have an antenna motor (typical motor that raises and lowers the antenna). we have that dot matrix, which has the antenna built into the rear glass. i assumed that simply connecting it just did everything, but that rear windshield has an antenna amplifier, and THAT is connected via the antenna turn on wire. again, when i did it, i simply connected it, and that was it. after reading it, i finally realized that although we don't have the motor, we have the amplifier. he could have possibly made the same mistake by not seeing a physical antenna that raises and assumed there was no antenna wire to turn on.
i would bring it back and have him check 2 things.
1) physical antenna main cable (the thick one) make sure that's connected.
2) check that antenna wire is connected.
I had the same problem. I had mine installed at a local shop and had to take it back twice before they could fix it. The second time I posted the problem on here and got some good replies (with pictures) which I printed out and took back to them. The used that to fix it. Unfortunately the serach is disabled for me but if you can search, try and find my post.
Okay, thank you for the explanation. I am almost sure that is what happened. I was there when he installed it and he asked me if I had a power antenna...I told him no so I am sure that is what happened. Thank you very much.
let us know when you get back. when i get home, i'll pull the FSM and show a picture of it just for future reference for anyone else.
Originally Posted by PoLo
yeah, ya got it.....when you see him, tell him that we dont' have antenna's, but we have built in antennas in the rear windshield, with an antenna amplifier. so that is, in a way, like the motor. turning on a typical motor is reallyl turning on the amplifier, activating the built in antenna.
polo do you happen to have that reference?
yeah my buddy just got an alpine installed in his 03 altima.....you need to purchase an amp for the antenna...its like 50 bucks....he got that installed by the same place and works fine now....
i've owned many a cars, down the list....
Datsun Wagon, Renault, Pulsar, CRX, 91Max, 92Max, then this one..
i guess i was just making a statement, as the maxima is the only car i truly know like the back of my hand....
I tend to get a bit irritable
Exactly how many bones are in the back of your hand?
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
This should fix your issue with poor reception. IThe tread is a bit old, back when i first got my '02, but it is the fix and should be the one for the '03 as well
http://forums.maxima.org/showthread....hreadid=122577
Give a shout if you need a hand.
ok, there is plugging in the antenna, which i assume you did, and then there is POWERING the antenna, which i made that silly mistake, so i can only assume you could have as well. one of the wires is the antenna turn on wire. i *think* you can connect that to your accessory wire on the radio, but your new radio harness should have a wire for the antenna.
i believe it was I that forgot that PoLo, you silly *****. lol. whoops...my bad.
Team STILLEN
08-10-2015 04:29 PM
