ohm questions....
Old Apr 4, 2001 | 01:35 PM
loudmaxima's Avatar
matts high current puts out 1200watts@.67ohms anyone know about what it'll put out at .5ohms??
Old Apr 4, 2001 | 09:48 PM
KidKeep
I could figure that out, but I'd have to ask a professor for sure, but the important part is not what it puts out, but what OHM level the amp is still stable.
If you drop the resistance through the speakers too much, your amp will shutdown or go into protect mode to prevent it from frying itself. If the amp can run at 1/2Ohms, then it's cool, but make sure you have the speakers wired correctly to yield the bare minimun stability rating of the amp, or else you could damage the speakers and/or amp.
good luck
Old Apr 4, 2001 | 10:06 PM
CanuckAMP's Avatar
I've got a friend that has a couple of factory modified D300HC amps that will do 2000Wrms.
Let me know if any of you fella's want one, and I'll get you in touch with him.
Old Apr 8, 2001 | 01:12 AM
edadams's Avatar
What type of amplifier are you asking about?
Old Apr 8, 2001 | 08:50 AM
Micah95GLE's Avatar
The MMATS D-100 HC.
jmlee44
Oct 2, 2022 02:13 PM
kjlouis
Nov 24, 2018 06:09 AM
jskirwin
Jun 8, 2016 08:49 AM
vybz05
Dec 10, 2015 07:38 PM
bryants95max
Oct 2, 2015 12:52 PM
