thump after shutting off help
Old Aug 20, 2004 | 10:54 AM
wade2ksleeper's Avatar
Every time i turn off my car after having the music playing about 5 seconds later the sub lets out one thump, what exactly is this. Is it a problem, if so what could be causing it and how do i fix it, thanks
Old Aug 20, 2004 | 12:36 PM
slickrick's Avatar
i had that when i had my amp hooked up to the stock non bose h/u. its fine. but i cant tell you why it does that.
Old Aug 20, 2004 | 02:15 PM
RiN'sMAX's Avatar
i have everything aftermarket as far as audio goes. mine does it too. did it in my 99 infiniti too
Old Aug 20, 2004 | 02:18 PM
mclarengts1's Avatar
mine does it too, i dont have a bose either
Old Aug 20, 2004 | 02:40 PM
nismos14's Avatar
§è~® f®ÈÄk
its the amplifier releasing the energy thats stored inside it. alot of times amps have soft turn-on and soft turn-off so you never hear that, sometimes it goes away. an easy fix is to put a switch on the remote wire going to the amp, and turn it off before you turn the stereo or the car off and the thump won't happen.
Old Aug 20, 2004 | 06:25 PM
adamlee2001GXE's Avatar
Uh oh, I dont have it, am I abnormal?????? hahhahha
Old Aug 20, 2004 | 06:28 PM
MIXXMAX's Avatar
Higher end amps don't have turn on/turn-off thump noises. Their circuitry are much better than the least expensive amps. Also, it depends on the manufacturer. The most common brand names are good from eliminating this noise.
Old Aug 20, 2004 | 09:29 PM
it doesn't really bother me, just makin sure it wasn't something wrong
DJLAX152
May 4, 2021 11:46 AM
Melissa40
Jun 30, 2017 10:04 AM
hayne
Oct 5, 2015 11:53 AM
Need help
23
Oct 2, 2015 08:56 AM
EdRomo86
Sep 12, 2015 07:49 PM
