my aftermarket system sounds like stock help!
Old Aug 31, 2004 | 01:26 PM
wariow's Avatar
Here's what I have, alpine type R components in the front with the tweeters mounted in the stock tweeter position, the rear holds kappas 6.5's 2 ways powered by a soundstream rubicon 600 watt 4 channel amp. Kenwood kdc 659 excelon HU as the source. I also have two 12" old rockford fosgate subs powered by a 150 watt kenwood amp. When my friends sit in my car they ask me if the speakers are stock
With this setup I think I should hear at least a lil difference but sadly I don't. I just hear stock tunes with heavy bass. I've had this setup for a coupla months now but it's really starting to bug me. The speaker wires and power wires are on opposite ends. The installation was a clean one. What could be wrong?
Old Aug 31, 2004 | 01:35 PM
filtor1's Avatar
Check your gain. Check your grounds from the front door speakers. Did you replace the speaker wires going to the doors or use the stock wire. Other than that I would guess something went wrong with the amp. These are just some of the basics things to check and varify. Also check the h/u's output. Maybe an internal eq setting is limiting it's output.
Old Aug 31, 2004 | 01:56 PM
MannyNJ2k2max's Avatar
Your strength is your frontage amp- try sound deadning the doors first- it will benefit your mids greatly
If that doesn't satisfy your fronstage needs try some high fidelity components.....Rainbow, DLS,Bostons, Focal,ID's, OZ Matrix's etc........
Old Aug 31, 2004 | 06:12 PM
adamlee2001GXE's Avatar
High fidelity components. Thats a new one. What exactly does that mean since I have some. HAH
Old Sep 1, 2004 | 12:49 PM
wariow's Avatar
so I should get some dynamat and do the doors then
Old Sep 1, 2004 | 03:07 PM
You should....Second Skin Damplifier is pretty cheap -look into it
Old Sep 1, 2004 | 03:10 PM
The point you are trying to make in this thread is???
Old Sep 1, 2004 | 04:00 PM
Yea, Read My Post. What Are High Fidelity Components?
Old Sep 2, 2004 | 05:25 AM
I should have said 'higher fidelity' components, which are made by companies that have dedicated themselves to speaker making, as the ones I listed above- I forgot a few....CDT makes great components as well-Speakers are the most important aspect of a sound system
Alpine, although a great company, has yet to impress me in the speaker dept-
but like I suggested first, a well sound deadened door can go along way in improving a midrange's output
Your post sounded more like you were bragging about your bottom of the bucket Focals, glad you like'm
Old Sep 2, 2004 | 06:12 AM
nope, just wanted to get more information about the speakers i bought. Yes, I love them, they rock.
Old Sep 2, 2004 | 10:37 AM
SKYRockerr's Avatar
make sure your filters are on hp or lp for subs and speakres once you break up the highs and lows and subs in the back ur gona be fine..
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
TheMafia
Sep 4, 2015 08:26 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
