front side door cup - speaker install
Old Sep 15, 2004 | 08:44 PM
nadir_s's Avatar
vicodin ... gift of life
so that cup that sits behind the door handle..... how the freak do you take it out?!
Old Sep 16, 2004 | 07:46 PM
joew's Avatar
i was impossible for me to remove. i also would like to know in great detail on how you folks remove it.
Old Sep 16, 2004 | 08:25 PM
AscendantMax's Avatar
http://carstereohelp.com/stereoremovalNisMaxFSpk01.htm
the panel?
Old Sep 16, 2004 | 08:48 PM
MIXXMAX's Avatar
Get a trim panel removal tool. It works wonders and saves you from breaking the tabs or clips from trim panels.
Old Sep 17, 2004 | 07:10 AM
Micah95GLE's Avatar
I use a simple flat-head screwdriver. Once you get one out the first time, make a mental note of where the tabs are so you'll know exactly where to insert the screwdriver and apply pressure (near the corners). They are no problem for me.
Old Sep 17, 2004 | 09:04 AM
joew's Avatar
i have looked at the site below before i tried to remove the door handle cup. the cup bent so much that i felt it was going to break and i stopped and gave up. mayby i door is especially tight. i have tried with a flat headed screw. i guess i can try trim panel remove tool.
Originally Posted by Fosgate Fan
Old Sep 17, 2004 | 09:50 AM
nadir_s's Avatar
i finally got it off after talking to Don.
Basically, you pop out the end of that panel (closest to lock). Then pull it back with your hands and all the way on the opposite end, both top and bottom, there's a tab. Just wedge a flat on the top part and pry it. Mine came flying out.
Old Sep 17, 2004 | 11:26 AM
joew's Avatar
i'll give it a try. thanks.
MikesChevelle
Nov 23, 2024 11:17 AM
JRod28
Feb 4, 2016 11:07 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 9, 2015 11:50 AM
