Amp mount behind folding seatbacks?
Old Sep 28, 2004 | 08:53 AM
Kal's Avatar
Kal
I'm thinking of mounting my jl 500/1 amp behing the rear seat on the drivers side. Im scared that if i screw it in that sometime later the amp might fall down. Can any one give me tips on where to mount the amp and what to use. I think the amp is about 5 lbs. Any info would help me since this is my first time with all this. Thanks.
Old Sep 28, 2004 | 09:14 AM
loulax07's Avatar
I'd say it'll be fine long as you use some coarse thread wood screws, not a problem
i've seen this done many times b4
Old Sep 28, 2004 | 02:37 PM
mendon99's Avatar
tastey wheat
i put mine right in the trunk on the left side... just screw the amp to a piece of plywood and punch a hole thru the carpet/plastic stuff there, theres a hole in the metal that you can attach the board to with a bolt. i did it with just one bolt, havent had any problems yet and it keeps it out of the way and looks nice.
Old Sep 28, 2004 | 03:37 PM
MannyNJ2k2max's Avatar
its fine on the 5th gen, but just be aware that its on a deep incline (almost ~60 degree angle) I had no issues, and had my 4ch that way for months
Old Oct 3, 2004 | 08:56 PM
Saddles's Avatar
false trunk and cut a hole out in the middle of the floor to showcase your amp :P...not really hard to do...looks really nice...amps out of the way...all criteria filled
Old Oct 4, 2004 | 06:08 AM
Smaynor2934's Avatar
i have the same amp and i just mounted it on the box with the same screws i used to hold the subs into the box....works fine for me, no problems at all
Old Oct 4, 2004 | 10:48 AM
2 Da Max's Avatar
what do u know im mounting my amp in a new location too, is it okay if i screw it up in the trunk on that plastic grey piece behind the rear seats?
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
