Need help programing Alarm remote
Old Oct 4, 2004 | 05:26 PM
pjalst
Normally I'd do a search before asking this question, but the search function is down at the moment. Anyone know how to program an Auto-mate car alarm remote? The FCC ID: EZSDEI467. I know you have to do something with the Valet switch and press some buttons. Can I get some help? Thanks in advance.
Old Oct 4, 2004 | 05:39 PM
yogi's Avatar
yea u have to put the car into acc position and press and hold the valet switch...turn the car off....that's how u get into the menu of the unit....let me know who makes the unit and the model....i`ll try to find a manual for it and let u know
Old Oct 5, 2004 | 12:14 PM
pjalst
It's an auto-mate , FCC ID: EZSDEI467. hope that helps
Old Oct 5, 2004 | 03:02 PM
maximaman10's Avatar
Here you go
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
