need help Amp & Sub install
Old Oct 6, 2004 | 01:44 PM
ronin22357's Avatar
a friend recently gave me an alpine amp and a 12" kicker in a box . i am not a car stereo person and dont know about how to go about installing it. i have a 99 with bose.
Old Oct 6, 2004 | 02:13 PM
exardus's Avatar
I just did my sub and amp install this weekend. Do you have a stock HU or aftermarket. If stock, then you will need a line out converter. I can't give you much info on that because i bought a new HU. But basically you will need to run a power wire from the battery to wherever you want to install the amp, and run rca and remote turnon cables from the head unit to the amp also. And then you gotta hook up all the wiring to the amp, and amp to the sub. And that's basically it. The hardest part is probably running the wires.
Old Oct 6, 2004 | 03:23 PM
ronin22357's Avatar
i have a stock bose HU . i have never done anything with stereo stuff . i have always been into engine and suspension stuff. i need to know what things i need to get to make it work.
Old Oct 6, 2004 | 04:23 PM
2 Da Max's Avatar
first off go to an electric store and get a power kit
Old Oct 6, 2004 | 04:36 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I've done plenty systems in my cars its simple, you can't run rca from the bose "obviously" so get a RCA kit (line out kit) from your nearest shop, that hooks up simply with the existing oem wire from the bose. do the power wires to the back and that hook up to the amp and should be it.
*****note that theres a turn on wire that need to be installed other wize the amp will stay on all the time or wont turn on at all. to find this wire is a wire on a swich it turns on when the car is on. this wire also goes to the radio find it splice it with 12, 14 gauge wire run that to the back with the 8,4, gauge wire to the amp.******
Old Oct 14, 2004 | 10:52 PM
cobymoby's Avatar
Yes you can run line outs directly from the Bose.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
