Power Inverter Question
Old Oct 7, 2004 | 11:04 AM
Kolyan's Avatar
I bought 400W power inverter and in order to use all 400W I think it has to run from the battery (or un-fused power source) and not from cigarette lighter. My question is this: Is there an un-fused power source near the dash or is there another way of wiring this? I want to install it under the passanger seat.
Old Oct 8, 2004 | 03:59 PM
Magikone69's Avatar
for a 400w inverter i wouldnt recomend anythig but a nice gauge wire and running it from the battery. those wires inside are to flimsy and imo wouldnt be too safe. i have my power inverter stored in my glove box with a 4 gauge wire running from my battery w/ a fuse in line. everything runs good with exception to the loud *** fan in my inverter.
Old Oct 8, 2004 | 08:18 PM
friendhasmax's Avatar
that inverter is capable of consuming 30 or more amps, so you should wire it to the battery and fuse it. safe to assume that is 400 watts max? if so use a 30 amp fuse. i don't know why it would say "un-fused power source", that makes no sense. it has to be fused.
Old Oct 11, 2004 | 02:45 AM
Kolyan's Avatar
alright then i will run a wire from the battery when i get some free time. btw the inverter already has a 40 amp fuse inside.
thanks
Old Oct 11, 2004 | 06:10 AM
thanks
the internal fuse will only protect the unit from an internal electrical failure. if your power wire feeding the unit were to short, there could be a fire if the power wire is not fused. it is the same reason why the power cable for the amps in the car is fused no more than 18" away from the battery post.
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
AT978
Sep 6, 2015 10:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
