Eclipse AV 8022
Old Oct 20, 2004 | 10:31 PM
friendhasmax's Avatar
Eclipse AV 8022
tested PoLo's head unit tonight with the oscilloscope. sub output was tested using a 30Hz test tone. volume up to 79 was undistored with no clipping. at 80 (the highest voilume setting), there was distortion. EQ settings were flat.
Old Oct 21, 2004 | 06:32 AM
MannyNJ2k2max's Avatar
nice test.....most impressed, considering its a flip
Old Oct 21, 2004 | 10:39 AM
MacAlert's Avatar
Did you guys figure out the clipping issue?
Old Oct 21, 2004 | 11:29 AM
being he has no external processors in between, his gigantic Eclipse amp must be acting up......amp is clipping
Old Oct 21, 2004 | 12:59 PM
manny...he's talking about why the signal cuts off when the horn is honked or a window rolls up or down...and no, we haven't figured that out yet.
Old Oct 21, 2004 | 01:03 PM
Maxima Dan's Avatar
LOL...that would totally suck. And I have to say, that's a new one.
Old Oct 21, 2004 | 01:37 PM
Pearl96Max's Avatar
I tend to get a bit irritable
...Its the installer
Old Oct 21, 2004 | 02:23 PM
buahaha......
I had no clue on that horn issue....very
Old Oct 21, 2004 | 05:54 PM
MacAlert's Avatar
Old Oct 21, 2004 | 07:26 PM
Dohcser's Avatar
Mind if I ask what setting you O-scope was on for looking at distortion? Because since distortion is induced closer to the noise floor at higher frequency and the O-Scope may be setup only to see the 30Hz sine wave it will not be visible without drilling more into the signal. Clipping will definately be visible.
Old Oct 21, 2004 | 07:53 PM
stfu man...lol it's the salesman
Old Oct 21, 2004 | 07:55 PM
it was no longer a pure sine wave at that point. the waveform was distored drastically.
indeed, it does suck lol
Old Oct 21, 2004 | 07:59 PM
Dohcser's Avatar
I guess there was a predicesor to this email about the symptoms. But what I can pick out is that when he hits the horn the music clips? Is it just the bass or everything? If so I take it you all checked the grounds?
Old Oct 21, 2004 | 08:21 PM
Pearl96Max's Avatar
The "salesman" never had that problem with the other "customers". Only the 'Special' ones
Old Oct 21, 2004 | 08:29 PM
the sub output and the high pass output loses signal totally when the horn is pressed or window is rolled up and down. all grounds/cables were checked.
Old Oct 21, 2004 | 08:31 PM
damn it don...i hate you
Old Oct 21, 2004 | 09:06 PM
Pearl96Max's Avatar
But I Looooooove yOu
Old Oct 21, 2004 | 09:31 PM
MacAlert's Avatar
Uhhhhhhhh, . I think I'll fix my speaker myself now.
Old Oct 22, 2004 | 06:37 AM
just because don is gay? that's not very fair.
Old Oct 22, 2004 | 06:58 AM
Pearl96Max's Avatar
But Im married..to a woman and you guys are still.... with each other.
Old Oct 22, 2004 | 08:41 AM
lol....dunno ....closet door is slightly open there buddy...
Old Oct 22, 2004 | 08:43 AM
I call for a complete gut and rewire of Marco's car- between the alarm,voltage meter, gamepube, and mad accesories and grounds- it could be hard to backtrack- he's got alot going on in there
Old Oct 22, 2004 | 09:31 AM
Pearl96Max's Avatar
YOU are the one that takes pics of ME
Old Oct 22, 2004 | 05:34 PM
you two are too much lol
Old Oct 22, 2004 | 06:45 PM
2 Da Max's Avatar
watup eric i started building the box today, ill post pix when im done
hawkdog
Apr 22, 2001 04:52 PM
RaYnMeLa
Apr 17, 2001 06:20 PM
wesley
Feb 2, 2001 01:31 PM
QUANSUNG
Dec 7, 2000 01:29 AM
