Amp wiring advice
Old Nov 12, 2004 | 01:57 AM
Slow Moe's Avatar
Amp wiring advice
Hi Guys looking for some wisdom from all you Stereo gurus out there.
I have a 4ch amp already wired in my car with 8 ga. wire and I went ahead and upgraded the amp with this one.
http://www.millionbuy.com/souvga3204.html
Do you think I would get away with using the same wires or should I up grade the power and ground to 4 ga.
Thanks,
Old Nov 12, 2004 | 07:18 AM
03SE2HEAR's Avatar
Here's what we're looking at: 160Watts RMS @ 4Ohms x4 @ 13.8V (Battery Voltage) = 46.38 Amps of current draw. Not really sure that the 8ga wire will be able to handle that amount of current draw. Keep in mind that 46.38A is going to fluctuate at different frequencies and the load will vary from 4Ohms when playing music. I guess what I'm getting at is go for the 4ga wire. There's a reason they have a 4ga connection on the amplifier.
Old Nov 12, 2004 | 09:05 AM
suprropmp's Avatar
i would upgrade.. possibly to even bigger than 4 just in case you want to add another amplifier later
edit: I had 4 gauge through my car and now I have to take everything out and run 1/0 gauge.. wouldve been easier to do it from the start
Old Nov 12, 2004 | 10:47 AM
Slow Moe's Avatar
Thanks guys for the replies, I guess I will just have to rewire.
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
