how do u disable the bose amps?
Old Dec 10, 2004 | 07:00 PM
PKaiser's Avatar
just like the title says, i want to disable the amps on the bose speakers, so i can use an aftermarket head unit. any help will be appreciated.
Old Dec 10, 2004 | 07:56 PM
2 Da Max's Avatar
you dont have to disable the bose amps for an aftermarket HU.
2 Da Max's Avatar
i am currently running my type R 2 way coaxials from the bose amp
Old Dec 10, 2004 | 08:08 PM
andy044's Avatar
RWD bolt-on conversion?
alright hes what i understand
the OEM bose speakers are 2 ohm (very low resistance)
to put an aftermarket HU in most putout power at 4 ohm
if you try running an aftermarket HU iv heard u will blow the HU in a day.
im putting in a clarion HU and new pioneer 4 ohm 6x9"s and just bypassing the amps (leaving them there, just to look pretty....)
this is the way im going, from all the research on the topic that ive done
tell me what your going to do
Old Dec 12, 2004 | 06:02 AM
2 Da Max's Avatar
what do you mean blow the HU in a day? i used 2 HU's for months now and they work fine. and i think the bose runs at 1 ohm.
Old Dec 12, 2004 | 06:13 PM
PKaiser's Avatar
ok so can anyone tell me how to do it?
Old Dec 13, 2004 | 09:31 AM
craig10114's Avatar
if your using an aftermaket head unit.....
install your head unit
Run new wires to your 4 speaker locations(not a nessesity but i find it easier when ur getting rid of bose)
Install your speakers
if you want to disable power to the amps then u can either remove them from the case or just unplug them. The rear amps are in that little basket and u have to remove those to put new speakers in. The front are in a pod to the side of the speakers if u remove the 4 screws on the top plate u can gain access to them to either remove or disconnect.
Old Dec 13, 2004 | 12:07 PM
PKaiser's Avatar
ok im sorry i definatly didnt explain everything good enough, i want to put my new headunit in and use stock speakers. from what ive heard you can bypass the amp by cutting wires and connecting them to the speakers or sumthing like that. im not sure what to do exactly thats why i need your alls help. which wires do i cut(colors would help) and which ones do i connect.
Old Dec 13, 2004 | 12:09 PM
2 Da Max's Avatar
why would you do that? even though bose are crap they sound clean and nice with a good aftermarket hu
Old Dec 13, 2004 | 01:29 PM
PhillyDonut's Avatar
PKaiser - "i want to put my new headunit in and use stock speakers."
get the OEM-2 from ebay (will also need standard non bose nissian wiring harness or you could be ghetto and splice the OEM-2 into factory harness) and keep your bose amp and speakers. --OR-- get the ROEM which is basically the OEM-1 with nissian harness integrated. With both, you need to adjust (or decrease) the 'gain' (not sure if that's the appropriate word).
if you want to use aftermarket HU and speakers, then do what craig10114 said above.
btw, i'm using the ROEM.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
