sub install need help!
Old Dec 12, 2004 | 01:13 PM
ronin22357's Avatar
just tried to install a sub & amp to my bose. power wire was no problem and i used a hi lo convertor. when i had everything done i turned on the car and the cd played for about 5 seconds then the "bose speaker fuse blew" what did i do wrong? i am not sure if i connected the hi lo adapter correctly, i am a noob when it comes to car audio . thanks in advance
Old Dec 12, 2004 | 01:55 PM
2 Da Max's Avatar
yo probably got the neg and pos wires from the hi low on the bose hooked up wrong. check to see if the colors are right and make sure they belong to the left or right side speaker. make sure your amp is grounded good also
Old Dec 13, 2004 | 09:40 AM
ronin22357's Avatar
still having trouble. this time a fuse didnt blow but i get nothing from the sub. the amp has power and the remote wire turns it on. it is so windy here that my paper that had what the wires are on the adapter blew away. the adapter has a brown,silver , green , blue and a black wire (i remember the black is a ground)
Old Dec 13, 2004 | 12:11 PM
2 Da Max's Avatar
hmm how exactly did you wire it? silver pos and neg on left and green.. hold on u got a different adapter. o sht thats the one i bought a couple months ago and returned. yo see if you could take that **** back its fawken retarded. the adapter you need has 4 wires. and 2 rcas. its soo much easier dude. and its like 10 bux
Old Dec 13, 2004 | 03:42 PM
ronin22357's Avatar
where did you get yours from? i got this one from partsexpress.com. it was like 5 $
Old Dec 13, 2004 | 05:47 PM
2 Da Max's Avatar
i got mine from my audio store. you could keep trying with that one if you want, but good luck. i mean atleast the amp turns, all you need is some sound. just look for HI-LOW ADAPTER
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
