Headunit shut off :(
Old Jan 4, 2005 | 07:22 PM
Zipp028's Avatar
Well I had my car on and I was listing to the radio I turned it up and it shut off. Along with it my clock went out. I found the fuse for the clock and that fixed that problem. But I didnt come across any fuses for my headunit. I even checked the fuse that is in my headunit and it was fine. Did i blow my headunit? It wont come back on. Im not liking the fact of no music or anything to listen to while i drive. Please help!
Old Jan 4, 2005 | 07:37 PM
sunten1
i would check your alternator.......or get it checked...sounds like its gonna die...happen to me, first HU then airbag light, air bags and then some other lights in the dash....
just a thought
Old Jan 4, 2005 | 07:42 PM
Zipp028's Avatar
well, my battery has been dying on me latly.. Hm.. how do i check my alternator?
Old Jan 5, 2005 | 06:32 AM
2 Da Max's Avatar
take it to autozone or pepboys
Old Jan 5, 2005 | 09:26 AM
Zipp028's Avatar
its just weird because the other daymy battery died then my passenger side fog and headlight went out, then my clock and my radio went out.. Fixed my fog and headlight and my clock. The clock was just a burnt fuse. Now i cant get the radio to work.
Old Jan 5, 2005 | 10:42 AM
sunten1
did you check the fuse for that?
Old Jan 5, 2005 | 11:22 AM
Micah95GLE's Avatar
You better check the alternator output ASAP. It sounds like maybe the diode in the regulator is blown and now the alternator is overcharging the system, and that's why all the electrical parts are burning out. It'll take you 5 seconds to diagnose with a multimeter.
Old Jan 5, 2005 | 05:12 PM
Zipp028's Avatar
ok, I have a multimeter my gf bought for me its a pretty nice one too. I just never used one b4, so i dont really know how to used and what to set it at and what numbers i should be seeing...
Old Jan 6, 2005 | 01:27 AM
suprropmp's Avatar
if everything else check the ground on your head unit.. highly unlikely that it just popped out but its possible
Old Jan 6, 2005 | 07:59 AM
Micah95GLE's Avatar
First, test the battery. With the engine off, set the multimeter to DC and touch the probes to the battery posts (red is positive; black is negative). You should get ~12.5 volts from a healthy battery (mine does 12.8). If it's less than 12 volts, then your battery is probably toast.
Second, test the alternator by running the engine while touching the probes to the battery terminals. You should get ~14 volts (I don't remember exactly what mine was when I checked it a couple weeks ago). If you get 15 or more at idle, then your alternator is probably not working correctly.
DJLAX152
May 4, 2021 11:46 AM
Excalibur23
Oct 13, 2015 04:33 PM
hayne
Oct 5, 2015 11:53 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
EdRomo86
Sep 12, 2015 07:49 PM
