amp wont power
Old Jan 22, 2005 | 08:51 PM
shmad's Avatar
amp wont power
i have all the wires hooked into the amp necessary for power--12v, remote and ground, and cant get the amp to turn on. i took the amp to best buy and they said its powering on when they hook it up. this leads me to one conclusion... my ground. at first i connected the ground to a random bolt in the trunk, and when that didnt work, i drilled through the right side of the trunk and bolted it down. still no power. where do u guys have ur ground running to? my bolt is on the trunk floor on the right side, near 2 other bolts that are already there. y the **** isnt this shiznit workin?
Old Jan 22, 2005 | 09:14 PM
1996blackmax's Avatar
Did you check the fuse on the power wire? The only other thing I can think of right now is that maybe your remote signal from the HU is not working.
Old Jan 22, 2005 | 09:45 PM
sunten1
waht bout inside your wheel well
Old Jan 22, 2005 | 09:50 PM
shmad's Avatar
the HU is brand new, and i checked to make sure i was soldering the right wires before i soldered the remote wire to the HU. ive had this system for around 4 yrs now, with same wires. could the wires be f'd up?
Old Jan 22, 2005 | 10:06 PM
AscendantMax's Avatar
go back to any of those grounding points and try to sand off any paint that's there to create a good metal to metal contact.
Old Jan 22, 2005 | 11:01 PM
wills5i2's Avatar
If your grounds are good and the amp is still not coming on, grab a multimeter and test your remote wire.. If you dont get any voltage from the remote wire, you couldve accidently burned out the remote circuit in the head unit.. if thats the case then you can wire in a relay to use the accessory circuit to power the amp..
Old Jan 23, 2005 | 08:01 AM
2 Da Max's Avatar
there are 2 wires on the hu that are blue.
Old Jan 23, 2005 | 08:10 AM
A32Matt's Avatar
what kind of headunit do you have? My buddy's Panasonic had trouble not powering up the amp. found out it was the remote lead coming from the headunit. Seems alot of the Panasonics have that problem. Take a 12v test lead and see if you are getting power at the power, ground, and remote terminal on your amp. if you are not getting power at the remote, you have to find another acc. source to power up the amp. i just tied in my buddys remote wire to the hot wire going to the headunit.
Old Jan 23, 2005 | 09:11 AM
Big_Ham's Avatar
MaximaFreak
As A32Matt says ... take a jumper wire from your +12V and wire it to the turn on. If the amp turns on, you have a problem with your turn on lead. In this case, tap into something else that only comes on with ignition.
Old Jan 23, 2005 | 09:23 AM
2 Da Max's Avatar
wire it to your audio fuse on your accessory, thats what i did with my stock bose hu
Old Jan 25, 2005 | 12:55 AM
shmad's Avatar
thanks guys, im gonna try that this weekend. i'll get back to u when i figure it out.
Old Jan 26, 2005 | 06:45 PM
Tigger's Avatar
If you have 2 blue wires coming from the head unit, make sure that you are using the one labled rem. If you use the power antenna lead, you amp will only work with the am/fm and not when a CD is inserted.
Old Jan 27, 2005 | 12:01 PM
shmad's Avatar
i have to go and "borrow" a voltmeter from my physics lab to see if the remote wire is putting out power. i drilled through the trunk and put a bolt thru, grounding it there. i did scratch off all paint before i grounded. the kenwood HU i put in was brand new, and i used the manual to correspond the wires as i soldered, b/c i was confused about the two blue wires. The amp doesnt turn on w/ CD OR AM/FM, so i dont believe that i soldered them incorrectly as tigger stated. i did quickly touch ground to power, seeing if it sparked. gave me a hellova flash. if the ground was really crappy, im assuming it would still give me a spark though. after i "borrow" -which i will return, the voltmeter, i'll get back to you guys.
Old Feb 4, 2005 | 03:29 PM
shmad's Avatar
so i tested it w/ the voltmeter. im getting about 13.8 volts from the battery, and .5millivolts from the remote. is this not enough power from the remote to amp to turn it on?
Old Feb 4, 2005 | 03:57 PM
Big_Ham's Avatar
MaximaFreak
If i'm not mistaken, remote wire should be 12V. It certainly should be more than 5mV.
Jumper a wire from your constant to your remote input.
Old Feb 4, 2005 | 05:06 PM
kpr10is's Avatar
+1 ^^ Do this first, if the amp turns on then you either wired it wrong from the headunit, or your head units amp turn on lead is shot. Or its rare but possible that you pinched/grounded the remote wire when you put a panel or rear seat back in. Take the voltmeter and test the remote wire at the head unit, if there isnt 12volts there, then wire up your remote wire to the red ignition wire going to your radio.
Kevin
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
