Settings on Amp
Old Jan 27, 2005 | 06:33 PM
MaximaSE2005's Avatar
Settings on Amp
I know that this is an Audio and Electronics question but would like to know if any of the 6th Gen's owners can help.
Hi all, need help configuring the settings for my Kicker KX600.1, first time installing an amp w/ subwoofer.
I'm getting my car back on Saturday and would like to know how to setup the Amp.
First off, I am hooking up the following to the factory Bose system w/ Nav.:
Kicker Solo-Baric S12L74 Subwoofer (DVC 4 ohms x 2)
Kicker KX600.1 Amp
R/T 793-12 Sealed Enclosure made of MDF with 1.00 cu. ft. of volume.
I will be wiring the subwoofer to make into a 2 ohm load. Basically, connect the 2 negatives on the woofer and then to the negative of the amp and the same with the positive to create a 2 ohm load. I have never done this before but that is what I have read and want to do. They say that by wiring the sub that way, it will give me the full power of the amp.
Now, what I want to know is how to set the dials on the amp. There are 3 dials.
1. X-Over Freq. (hz) 12dB/Oct from 50, 75, 100, 125, 150, 175 & 200.
2. Gain Low Level 170mV-5V & High Level 340mV-10V from 0-11
3. Bass Boost (dB) @ 40 Hz from 0, 3, 6, 9, 12, 15 & 18.
And also a remote Bass Leverl Remote.
Any help is greatly appreciated. I will definitely post the pics once it is installed.
One last thing, I read on Cardomain that I will need a 4 gauge power lead for this amp but I got the amplifier kit that has an 8 gauge power lead for maximum of up to 600 watts, will the 8 gauge be ok?
For the people that have not seen what has happened to my car, take a look at the link below.
http://www.cardomain.com/memberpage/767560
Old Jan 27, 2005 | 07:12 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
link does not work.... this will help you learn bout how to wire the sub to an 2 ohm load...
http://www.jlaudio.com/tutorials/wir...dex.html#2svcp
x-over: 75 hz
gain: leave at around middle
bass boost: turn the radio up till it get loud and adjust the boost till the spk distorts then turn it down alittle.....
Old Jan 27, 2005 | 07:14 PM
pae1215's Avatar
damn, some smack.... http://www.cardomain.com/memberpage/767560
link works
Old Jan 27, 2005 | 07:15 PM
Try the link now.
Old Jan 27, 2005 | 07:51 PM
Tek-Niq's Avatar
what happened this thread didn't help:
http://forums.maxima.org/showthread.php?t=374316
Old Jan 27, 2005 | 08:00 PM
No one was responding at first. All is good now.
Thanks!
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
