I need help with this...
Old Jan 30, 2005 | 09:57 AM
Cam'ron 03's Avatar
my dome lights, power locks, rear defroster, my ignition light doesn't work at all...I know it can be a fuse but which fuse is it? an where can I find it ???????
Old Jan 30, 2005 | 08:27 PM
ThumpinMaxima's Avatar
do you have your car manual?
Old Jan 31, 2005 | 06:45 AM
motocross416's Avatar
Look to the left and down from your steering wheel, there is a panel there that just pulls off. There are a bunch of fuses, if one is blown you should be able to see that it is. Then just pull the bad one out and put a new fuse in.
Old Jan 31, 2005 | 12:26 PM
Cam'ron 03's Avatar
ok I did that but nothing came back on....so wats the next thing that can be the problem?????
Old Jan 31, 2005 | 12:37 PM
Assassinroon's Avatar
hey did you get a volt meter and test all your fuses. Usually the electrical fuses are the one thats blown check those. IF not go in the hood and check the fuses in there
Old Feb 1, 2005 | 08:13 AM
Cam'ron 03's Avatar
thanks i found the problem...I appreciate the info
Old Jan 16, 2006 | 09:56 AM
kbjy11's Avatar
can i ask how you fixed the problem?
i have the EXACT same problem.
let me know, Thanks!
Cotozic
Jun 28, 2017 08:01 PM
dashingMax
Mar 4, 2002 01:03 PM
Justin95SE
35
Mar 4, 2002 10:57 AM
dirksmoothe1
21
Feb 22, 2002 12:46 AM
BigBICHDog
Feb 21, 2002 08:25 PM
