AMP MOUNTING help
Old Feb 9, 2005 | 02:35 PM
tslrock514's Avatar
AMP MOUNTING help
What is a good way to mount my amp in my trunk. If ya got a good spot for it and any ideas please let me know.
Drew
Old Feb 9, 2005 | 02:46 PM
Flava_24/7's Avatar
Boosted Panda
Well, you could mount it to the speaker box, place a board under the carpet and mount it to there etc. Just get creative.
P.S. this should be in the stereo section.
Old Feb 9, 2005 | 02:49 PM
MAXRB8's Avatar
Rightside up with metal straps attached to rear speaker deck. Do not mount upside for ease sake as the heat fins won't do their job of cooling down the amp. I have a 600w Conceptamp big but slim so the trunk link bars don't hit it.(I'm talking about the link bars not the hinges), this way I can unplug my sub at the speaker connection pull out my sub and use whole trunk with ease!
Old Feb 14, 2005 | 01:35 PM
tslrock514's Avatar
hey max...you think you could get me a picture of what yours looks like?
Old Feb 14, 2005 | 01:50 PM
A Flood99's Avatar
you could do something like this......
Old Feb 14, 2005 | 01:52 PM
Big_Ham's Avatar
MaximaFreak
I mounted mine under my subbox. Subbox is suspended using the RSTB ... but could easily be suspended by using wooden legs also. To get to the amp I have to remove the subbox ... but I never have to get to it.
NEVER mount the amp directly to metal. Mount it to wood and secure the wood to metal.
Old Feb 14, 2005 | 02:08 PM
sterlingmissile (the .org scammer)
Big Ham -can you post pics of your install? Would like to do the same. Right now I have a full plywood trunk setup and would like to have the amp mounted like you said and a mini sub box in the tire well. Saves a ton of weight!!!! Would appreciate it.
Old Feb 14, 2005 | 02:20 PM
pavelsmax's Avatar
I have mine in the hole in the rear seats... i cut a piece of wood painted it black (you cant see it anyway) and bolted it to the back of the seat frame
i had to remove the black plastic piece but the amp fits perfectly i can raise and lower the armrest to allow peope to sit in the middle
just an idea
Old Feb 14, 2005 | 02:29 PM
Big_Ham's Avatar
MaximaFreak
http://www.maximafreak.com/stereo/stereo.htm
Old Feb 14, 2005 | 04:52 PM
2 Da Max's Avatar
thats nice pavels max, but mine is very similar to a flood99. i would say if u dont want to mount it to the box then imo that would be the 2nd best place to fit it. btw check out hte sticky at the top to get some ideas
Old Feb 14, 2005 | 07:05 PM
WaarrEagle's Avatar
Old Feb 14, 2005 | 07:07 PM
WaarrEagle's Avatar
Why do you say this? I have my amp screwed into metal but there is plastic insulation and peel and seal between the amp and the metal that it is screwed in to. Is this OK and if not why?
Old Feb 14, 2005 | 07:32 PM
Crockpot's Avatar
I've had my pos amp mounted on metal for almost 6 months now...
Old Feb 14, 2005 | 07:34 PM
Big_Ham's Avatar
MaximaFreak
Grounding. You're grounding it to the rear deck at multiple places ... you can get ground loops. You also have a ground wire likely running to a different location as well. There may be other dangers as well, but I don't recall it being unsafe.
Old Feb 14, 2005 | 07:57 PM
2 Da Max's Avatar
i once grounded my old xplod amp to itself...trust me its not pretty
Old Feb 15, 2005 | 07:29 PM
tslrock514's Avatar
A Flood 99. I see what you are saying but where can i get that piece to mount my amp on???
Old Feb 15, 2005 | 08:22 PM
Big_Ham's Avatar
MaximaFreak
If you don't know the answer to that already, please take it to a trained professional. He'll be a second set of eyes on your wiring as well ... this is important for safety.
Old Feb 20, 2005 | 05:23 PM
Anyone else have pics of mounting right on back of back seat?
Old Feb 22, 2005 | 12:44 PM
machinehead's Avatar
pack of the seat is probably the easiest.
Old Feb 22, 2005 | 06:09 PM
Pics anyone? Please.
Old Feb 23, 2005 | 08:40 PM
tslrock514's Avatar
i definatly know how to wire it...that is no problem i just need to know where i can mount it without like customizing my trunk...too lazy. I also wanted to know where i can run my 4g wire into the cabin
Old Feb 24, 2005 | 09:21 AM
HomerMAC's Avatar
Donating i30 Owner
i wanted to mount it between the rear speakers inside the trunk.. upside down... u get what im saying.. si there any probs with that... i wanted to enlcose it and put some fans on it.. good idea..?
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
