need dynomat help
Old Feb 27, 2005 | 04:54 PM
roll4life's Avatar
need dynomat help
i m going to put dynomat all over my car soon and i was wondering how difficult is it to take the inside of the doors off..like the panels..on a 01 maxima..do you have to just pull them out? or what
thanks guys
Old Feb 27, 2005 | 05:21 PM
Torgus's Avatar
you must have alot of money to fully dynomat your car. personally i'd look to alternatives before i bought dynomat...
the door panels are held in like most door panels...with body clips.
Old Feb 27, 2005 | 05:57 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
remove the trim ring around the door handle
remove the plug and screw from inside the door pull cup, remove the cup
remove the two screws from the bottom of the door
pulling the rear of the door up, tilt it forward and up, and remove the clips.
dont do the whole car chase down the rattles and mount squares under and around our speakers. youll be fine. linex is a good alternative.
Old Feb 27, 2005 | 08:21 PM
roll4life's Avatar
"remove the trim ring around the door handle" outside or inside the car?
Old Feb 27, 2005 | 10:00 PM
Slow Moe's Avatar
The plastic trim you need to remove is on the inside door handle.
Old Feb 27, 2005 | 10:42 PM
BRINKLEY's Avatar
be careful removing the trim ring, its kinda tedious to get it off without breaking the clips. The second one is alot easier once you see how it is clipped. And as far as the screws at the bottom? I think the 5th gen. only has two screws, the one under the plug up towards the front, and the one in the handle.
Old Feb 28, 2005 | 09:15 PM
roll4life's Avatar
so by doing this i will be able to get to the metal part of the door and is it hard to put the paneling back on?
Old Feb 28, 2005 | 11:34 PM
Slow Moe's Avatar
Yeah you'll get right to the metal but you will have to remove the clear plastic liner. Putting the panel back on is really easy.
Old Mar 1, 2005 | 12:47 PM
machinehead's Avatar
try using something cheaper than dynamat. dynamat is overpriced.
Edead: www.edesignaudio.com
RaamMat BXT: www.Raamaudio.com
Second skin: www.secondskinaudio.com
NewEngSurf
Apr 7, 2005 10:24 PM
Dstyle
20
Jun 25, 2003 06:57 PM
nadir_s
Sep 26, 2002 11:56 AM
ThumpinMaxima
May 29, 2002 04:12 PM
97SEMAX
Aug 20, 2001 07:25 AM
