Alternator WHine still there
Old Mar 8, 2005 | 11:23 AM
Assassinroon's Avatar
For those hwo dont know me i have a kicker amp powering my internal speakers Alpine type s (Comp in front COax in back) and a JBl 600.1 powering my 2 12 in shivas.
Long story short i got alternator whine i checked every possible wire and im still getting it. I changed grounds and what not . However now my sound is fading in and out on the interior speakers. The subs still bump but no sound or whine from interior speakers. THen after a while it will come back or if i tinker with the RCA cable going into the kicker amp it will come back.
I also tried a alternator filter and that did not help. ANy suggestions ?
Old Mar 9, 2005 | 02:34 AM
Tony Fernandes's Avatar
Have you tried replacing the RCA cable?
Tony
Old Mar 9, 2005 | 07:21 AM
yes i did still didnt work
Old Mar 9, 2005 | 10:44 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Have you tried a ground loop isolator ?
Old Mar 9, 2005 | 10:49 AM
If the sound is intermittent when you tinker with the RCA inputs on the Kicker amp and you're sure it's not the cable...
EDIT: Another hint... And if the sound is intermittent on all your speakers that are running off the Kicker amp and you're sure it's not the cable...
(the answer should be quite obvious)
Tony
Old Mar 9, 2005 | 01:49 PM
KCMaxima98's Avatar
Don't do that. I tried the PAC isolator and the radio shack. They actually induce noise themselves if not positioned correctly. Also, it cuts out mid-bass. That is not speculation either. I tried them.
Old Mar 9, 2005 | 02:13 PM
slickrick's Avatar
i told him it was the kicker amp, but he just got it and it worked fine at 1st, so i was confused.
Old Mar 9, 2005 | 08:37 PM
yeah i tried 3 rca cables its not the cable and the amp was bought brand new
Old Mar 9, 2005 | 09:33 PM
VQuick's Avatar
Chassis Freak
If you mean the alternator itself is whining, your alternator is dying. Probably won't last long. But if you're just getting a whine through your speakers, never mind. Just thought I'd post in case.
Old Mar 10, 2005 | 01:19 AM
slickrick's Avatar
its his interior speakers which does lead me to believe somehow the inputs on the amp got messed up.
Old Mar 10, 2005 | 02:29 AM
That's the conclusion I was trying to get him to find on his own.
Tony
Old Mar 10, 2005 | 11:20 AM
is there any way to test the input on the amp i cant hook up the speakers to the jbl amp cuz that would blow them !
Old Mar 11, 2005 | 07:20 AM
bizzump audio heads !!!
Old Mar 16, 2005 | 12:13 PM
GUys i have turned off the stereo lol the alternator whine is too much for me. THe subs will only leave again if i can get this stuff fixed. Pearl im counting on you lol
Old Mar 16, 2005 | 02:32 PM
suprropmp's Avatar
heh, I've done the same... your head unit ground might be bad like I suspect mine is
Old Mar 16, 2005 | 03:37 PM
Did you not post a long time ago that if you played around with the RCAs going into the amp the noise would come back? And if you tried a few different RCA cords and ruled them out then what else could it be? If everything you've told us is true, it has to be the RCA inputs on the amp. How can we convince you of this?
Tony
Old Mar 17, 2005 | 10:50 AM
Is there anyway to check this wihout getting another amp sent over?
TallTom
57
Oct 14, 2025 05:16 PM
homewrecker
Sep 24, 2015 07:01 PM
