I can barely hear my bass...
Old Mar 12, 2005 | 08:02 AM
tavarish's Avatar
fwd gone rwd cr00
I just installed my 2 12" Sony Xplods, 1000w Kenwood amp, and I can barely hear my bass...with all the settings on my amp set to max. I have it spliced into the rear speaker deck and then I used a line ouput converter to convert the signal to RCA...could it be that the gain is set really low on the converter? It's weird that my friends, who have 1 12" in their trunk and have an amp that has half as much power as I do hit so much harder..
Please help.
Thanks.
Old Mar 12, 2005 | 08:16 AM
kcidmil's Avatar
Some of the line converters do offer a gain adjustment. Check that out first. If not, try checking the connections. Also, double check the wiring from the amp to the sub. If the wiring is reversed, it'll cause the signal to be really low, if not work at all.
Old Mar 12, 2005 | 10:48 AM
Scope's Avatar
Im izz sexay
DO you have a high-pass and low-pass filter?
Old Mar 12, 2005 | 11:15 AM
tavarish's Avatar
fwd gone rwd cr00
no, i don't have a hi or low pass filter...i dont think i do...
Old Mar 12, 2005 | 09:58 PM
ramtaajogi's Avatar
turn your SUB on from your HU...its probally set to OFF. what kinda HU you got. you sure you put the wires into the right RCA connectors in the back of the HU.
Old Mar 12, 2005 | 11:23 PM
2 Da Max's Avatar
check grounds
Old Mar 13, 2005 | 12:40 AM
kpr10is's Avatar
+1 make sure one sub isnt out of phase, meaning one of the subs would have its (+) and (-) wires reversed.
Do you have Bose? Did you tap into the wires for the high-low before or after the Bose amps?
Old Mar 13, 2005 | 04:07 AM
kcidmil's Avatar
Try reading the post first
Old Mar 13, 2005 | 06:22 AM
tavarish's Avatar
fwd gone rwd cr00
i tapped after the bose amps, but i checked the wiring yesterday, and all i can say is my system is LOUD....i set off a few car alarms...and my lights don't dim anymore..
Old Mar 13, 2005 | 06:28 AM
Conrad283's Avatar
I need a truck
Congrats to fixing it yourself.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
