subwoofer delay?
Old Mar 13, 2005 | 07:45 AM
tavarish's Avatar
fwd gone rwd cr00
subwoofer delay?
I've realized that my subs have a delay in them, especially listening to techno, or anything with a fast paced constant beat...it's about a half second off...i have it connected to the bose rears (spliced with a LOC)...how do I get rid of this delay?
Thanks.
Old Mar 13, 2005 | 08:24 AM
kcidmil's Avatar
Well it could be the fact you're using the LOC. Another could be too small of a wire for power, ground, and speaker. Another could be the amp itself.
Old Mar 13, 2005 | 09:57 AM
1996blackmax's Avatar
Try reversing the phase on the subs. Meaning that instead of the + and - wires from the amp going to the + and - of the woofers, have the +'s of the amp going to the -'s of the subs, and the -'s going to the +'s. I think this may do the trick.
Old Mar 14, 2005 | 07:10 AM
Micah95GLE's Avatar
How do you have the sub installed in your car? Which way is the sub facing?
Old Mar 14, 2005 | 07:42 AM
tavarish's Avatar
fwd gone rwd cr00
i tried it facing the seats, but didn't like the way it looked, and i turned it around (facing taillights) and the sound is the same.
Old Mar 14, 2005 | 08:25 AM
NEW2DAGAME's Avatar
What type and size enclosure do you have?
Old Mar 14, 2005 | 09:25 AM
tavarish's Avatar
fwd gone rwd cr00
it's a sealed box, open air speakers.
Old Mar 14, 2005 | 11:05 AM
Have you tried reversing the phase on the subs?
Old Mar 14, 2005 | 02:43 PM
Micah95GLE's Avatar
You can try messing with the phase, but I think you're gonna find that the delay is a characteristic of trunk-mounted subs. I had that problem in my first Maxima. In my new Maxima, I mounted the subs in the rear deck, playing directly into the cabin. In addition to all the other benefits of this set-up, the attack is dead-even with the mids up front. It sounds as if the subs are mounted up front. I'll never have a sub in my trunk again.
Old Mar 14, 2005 | 03:20 PM
If you have a CD player that has the time delay feature, & a trunk mounted sub, you can tune the system not have this delay .
Old Mar 14, 2005 | 04:13 PM
SuBXeRo's Avatar
the subwoofers should not be off at all, i too listen to techno club rave, all extremly fast beat songs, my subs hit every beat. i also have 2 12" type r's each in a sealed chamber approx .89 cubic feet each, fit up to my backseat, meaning the box has an angle in it, and they are facing towards the trunk lid. It depends on the subs you have, and i mean it depends alot on that, type of enclosure is very important also. another thing is, u shouldnt use high level inputs to connect to your amp, it has extremely poor sound quality that way, you should use a converter, highlevel to rca, tsunami makes a very good one. the difference is night and day clarity. i am very much a sound qaulity freak, so i am always looking for a way to improve. important key is the equipment you have, poor equipment = poor sound. i hope this helped, the freq line should be set as low as it can go on your amp, mines around 40 hz i believe, but that would help pick up on more beats, shouldnt be the cause of your delay, and like it was previously stated, ground should be strong, and proper size wires should be used. i hope it helped, any more question IM me on aim, im more than wiling to help
Old Mar 14, 2005 | 04:18 PM
Max_N_Action's Avatar
dude i have the same EXACT problem...i am also using the factory bose head unit and running it off the back speakers....im gonna get a hi to low level converter soon and try that....let me kno what u try to do...
Old Mar 14, 2005 | 06:18 PM
tavarish's Avatar
fwd gone rwd cr00
the tsunami line ouput converter is the one i bought...i guess it's because the signal is being fed through so many places..oh well, its not so bad if you think about it..
Old Mar 14, 2005 | 06:29 PM
AscendantMax's Avatar
what frequency line?
back on topic, what kind of subs are you running?
Old Mar 14, 2005 | 07:49 PM
SuBXeRo's Avatar
your amplifier can be set to allow a freq bandwith to go through, like on my amp, i have a rf 1001bd, i can have th amp pick up freqs as low as 40 hz up to like 140 hz
Old Mar 14, 2005 | 09:01 PM
oh, that's the crossover
jskirwin
Jun 8, 2016 08:49 AM
sliptap
Sep 30, 2015 05:57 AM
starman9215
Aug 11, 2015 06:51 PM
