New system in 6th Gen
Old Mar 13, 2005 | 10:07 PM
MaximaSE2005's Avatar
Hi guys!
Here is what I want to do. Buy a new HU, Components, rear door speakers, rear deck speakers and a amp to power the new speakers.
My question, is what type of amp do I need? And how will I run the wires to the amp? For ex. Where will the component (in the front including tweeters) wires run to on the amp, where will the rear door speaker wires run to the amp and where do the rear deck speaker wires run to the amp? That is if I get a 4 channel amp or is there another amp with more channels?
Please assist.
Thanks!
Btw, I have a PAC converter for my subwoofer to change the factory HU to make them have RCA outputs. Since I will be replacing the HU, I guess that there should be a set of pre-amp outputs to run to the amp for the subwoofer and to run to the amp for the new speakers.
I just need a lot of help!
Thanks!
Old Mar 24, 2005 | 10:51 AM
tooshort_128's Avatar
I've got the same question about the exact same car. Let's bump this!!
Old Mar 24, 2005 | 10:57 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Jesus, dude. That is waaaaayyyyy too many questions at one time. Let's start with the obvious: how much are you looking to spend?
Old Mar 24, 2005 | 12:36 PM
MacAlert's Avatar
First question, what is your budget?
Old Mar 24, 2005 | 01:06 PM
Conrad283's Avatar
I need a truck
Since we're all posting the same question.
What's the most you'll spend?
Old Mar 25, 2005 | 07:36 AM
I just wanna know if a four channel Apline amp at 55 x 4 rms will be enough for the front door speakers, rear door speaker, and rear deck.
Old Mar 25, 2005 | 07:38 AM
Oops, I meant Alpine
Old Mar 25, 2005 | 07:42 AM
Maxima-Ness's Avatar
depends on what you get. COMPLETELY!!! A 55x4 amp might be good depending on your choice of speakers. Ill be running an ARC 4150XXK with the Rainbow Profi/kickbass, and I definately know that the Alpine amp would not be powerful enough for that.
Again, whats your budget?
Old Mar 25, 2005 | 09:02 AM
I was planning on doing Alpine Type-S's all the way around; in the front and rear doors and the rear deck. If I wired the amp through the factory speaker leads, would that even the power distribution from 4 channels to all 6 speakers? The Type-S's are 40 watts rms each, so that's 240 watts total rms. The Alpine pushes 220 watts total. The speakers are pretty sensitive so I figure they will play loud.
Old Mar 25, 2005 | 09:04 AM
By the way, I have a 6th gen non-bose.
Old Mar 25, 2005 | 09:31 AM
Sure, sounds like that should work. 40w speakers? does anybody know for sure if thats a downgrade from stock?
Old Mar 25, 2005 | 09:32 AM
before you make your speaker decision, check out http://car.rainbow-audio.de/home/home.php?lan=3, they have plenty of different price ranges and i assure you that youll be happier with any product you purchase made by them.
Old Mar 25, 2005 | 09:52 AM
Watts RMW are a thermal rating and does not mean that you will be pushing 40watts.
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
2k0to2k3
Aug 18, 2015 09:59 AM
wyobbagy
Aug 15, 2015 02:28 PM
