My System Sounds Bad Any Tips?!?!?!?!?!?
Old Mar 14, 2005 | 11:02 AM
f550maranello2's Avatar
ALRIGHT i have a pioneer deh-p6400 head unit, fosgate 12inch p3's (2@2ohm) and a fosgate amp p8002 1000watts rms/3000 peak. im running 2 channel. i have a sealed box and a vented box and with either it just doent sound like it supposed to( boxes are the correct volume)... i turn it up and after a certain point it just doesnt seem to get any louder it doesnt give me the low bass that it supposed to. Please offer some help cuz it frustrating....
Old Mar 14, 2005 | 11:11 AM
2 Da Max's Avatar
wow you serious? even in a sealed box you should get some lows, you check all your wiring? and your gains? check your grounds too that was my problem back when
Old Mar 14, 2005 | 11:16 AM
Na man all grounds are good, all connections are good, gains are good too... i think im gonna try this in my buddies car today cuz its really getting the better of me.. i mean with this much power it should make the trunk come off lol jk
Old Mar 14, 2005 | 11:27 AM
MannyNJ2k2max's Avatar
...that amp doesn't put out no where near 3000watts peak
- if each sub is a dvc 2ohm, you should have each sub wired to its own channel for 1ohm stereo load (rated 400rms x2 @1 )
- you should have 1/0 gauge wire going into the amp from the battery. The amp is a power hog and at 53% efficient full tilt it needs proper wiring- in case you dont have it set up that way
If these are correct these could be your problems
1- those subs plainly suck
2-you amp is putting down no where near what it claims
3- you expect to much out of the Maxima with that power
Old Mar 14, 2005 | 11:36 AM
uhhhhhh no. the amp is 2 ohm stable genious... meaning that i can run 2 2 ohm subs... the amp actually puts out 996 watts rms bridged and 2856 peak bridged... thats about 500 rms one channel @ 2 ohm...thats what the spec sheet says... then the suggested wire size that is supposed to go in is 4 gauge the amp is also 65% efficient.. and lastly those subs do not suck
Old Mar 14, 2005 | 12:06 PM
2 Da Max's Avatar
2 ohm and 2 ohm is four ohm lol jk
if its a 2 channel it should always play at 2ohms when brigded. check this out
http://www.jlaudio.com/tutorials/wiring/index.html
Old Mar 14, 2005 | 12:10 PM
its max power is transfered at 4 ohms bridged... im running 2 ohm per channel
http://www.rockfordfosgate.com/produ...h%20Amplifiers
Old Mar 14, 2005 | 12:16 PM
2 Da Max's Avatar
oo nice amp, so it should be running at 4 ohms at 800 rms
how did you wire the subs?
Old Mar 14, 2005 | 12:22 PM
So its a DVC 4ohm sub(subs) , not 2 'ohm' subs....
I thought youhad a Power T8002 (which I happen to own BTW), it seems you have the lesser Punch- my misunderstanding - Anyways dont go by those birth certificates-all they are is a piece of paper. You should be seeing 400rms to each sub
Old Mar 14, 2005 | 12:24 PM
from what he is phrasing it it seems he has a sub to each channel-2ohm stereo
Old Mar 14, 2005 | 12:27 PM
lol guys alright to clarify everything... im running at 2 channel... each channel has a 2 ohm load(sub) on it... eithier way it should still pound u know what i mean... my buddy has a 350 watt rms amp (jensen) and a single cerwin vega 12 in sub...i almost blows the doors off the car
Old Mar 14, 2005 | 12:28 PM
2 Da Max's Avatar
its in a sealed box right? maybe those subs arent all that man. what are the specs of that sub
Old Mar 14, 2005 | 12:30 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Actually those subs do suck, but thats besides the point.
The sheet is just a piece of paper.
That amp will produce No Where near that rating.
Your car couldnt handle anywhere near that power IF the amp was even able to produce it.
Not to hurt your feelings, but I would take lesser rated amps/speakers and **** on the RF products. You fell into the loop of all the RF products hype. Its ok, everyone learns at one point or another.
AscendantMax's Avatar
is there a subsonic filter on that amp? it could be set too high and not give you the low bass.
Old Mar 14, 2005 | 12:34 PM
Pearl96Max's Avatar
BTW, dont take the post above as offensive, just factual. Not trying to "Flame" anyone here...
ummm the box is .75 cubic feet for each sub exactly what the spec sheet suggest for best sound. yea and i have a vented box as well that within specs but the sound isnt that good.. like i said when i crank it it flat lines real fast.. cound it be cuz of the deck?
Old Mar 14, 2005 | 12:39 PM
yea im gonna disagree with u on the subs i have them set up at work and they pound with the same amp... im begging to think that its the deck.. cuz like i said my buddies car has a crappy amp and a ok sub and it serioulsly wants to take the doors off the car...
Old Mar 14, 2005 | 12:42 PM
Pearl96Max's Avatar
Then well have to agree to disagree, as Ive dealt with RF for over 10years. So if your ears likethem thats fine, I was just stating facts as well as personal preference, not Just opinions.
Old Mar 14, 2005 | 12:45 PM
Maxima's arent the greatest for sound bro, at least SPL wise....unfortunatly
Old Mar 14, 2005 | 12:48 PM
2 Da Max's Avatar
why is it because of the design of the rear deck?? or big **** trunk?
Old Mar 14, 2005 | 12:49 PM
Well... like iv been saying jenson is crap and cerwin vega isnt that great either but sound quality wise it sounds real good.. and since what i got in my car is a whole lot better then what my buddy has... how on earth does his sound better...and is over all louder... could the pioneer deck be the culprit i have a booser amp connected to the rca giving me about 3.8 volt pre-output. which doesnt show any clipping...? i just need some answers cuz it probably someting real stupid thats messed up and im having a real hard time finding it thats all...
Old Mar 14, 2005 | 12:56 PM
Pearl96Max's Avatar
Booster amp? Line driver you mean? please specify
Old Mar 14, 2005 | 01:03 PM
line driver sorry...right now with the radio's 2 volt output it puts out 3.8 volts without clipping
Old Mar 14, 2005 | 01:06 PM
Pearl96Max's Avatar
What LD is it and how did You verify the non clipping?
Old Mar 14, 2005 | 01:11 PM
well its install edge...i hooked it up to a fuction generator imputting the 2 volts @60 hertz then i adjusted it until the output was (on the scope) about 3.8 volts wave with no signs of clipping... after the 3.8 volts it started to clipp
Old Mar 14, 2005 | 01:40 PM
how high are your gains set?-Reason i ask is because I've had to have the gains on the T8002 nearly at 80-90% (no kidding) to a set of Diamond CM3 components(120rms) to get them to even play as loud as you'd expect from an underated 125rms per ch amp- mind boggling actually. I know its not the amp, the first fried and RF issued me a new one-same thing
This off a 4v JVC Arsenal deck
Old Mar 14, 2005 | 02:56 PM
well the gains are set to about 70% on the amp and neg 1 on the radio... and about 70 on the bass ****... the other gains on the radio are set to 3 on the equalizer (out of 6) and cut off is set to 100 hertz
Old Mar 14, 2005 | 07:29 PM
2 Da Max's Avatar
70 is about the limit, but you have a line driver it shouldnt be that high. you should lower your gain to half way and raise up the sub controller. is the bass **** the bass boost? if its a good sub you dont need it it should be at zero
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
