Running new wires through door
Old Apr 2, 2005 | 02:48 PM
WaarrEagle's Avatar
How on earth do you get new wires through the grommet in the front doors? Just looking at them there is no way you can just fish the wire through. I can't even find where they come out inside the car. I am wiring an amp to power a set of components so I can't use the stock wiring. I need help badly.
Old Apr 2, 2005 | 03:09 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You can't. You have to run them through a different spot on the door.
Old Apr 2, 2005 | 03:16 PM
WaarrEagle's Avatar
Well that blows - I guess I can run it out by making a new hole in the grommet in the door but whats the best way to get it into the cabin?
Old Apr 2, 2005 | 03:41 PM
plurco's Avatar
ok man here is the easy solution.
All you have to do is make a small hole in both of the grommets with a razor knife. Don't worry about trying to get the wires through the factory loom because you never will. Run the wire through the two holes, and use electrical tape to hold the wire to the factory wires. Then get some 1" split loom and work it over the factory wires and your new wires, and you are done. Looks perfect.
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
