where did u put you amps in a 5th gen
Old Apr 4, 2005 | 10:19 AM
krmaxima's Avatar
well i have two amps that are pretty big that i need to install. i dont really want to lost trunk space but there is really no were to put these amp. can some one post a pic in where to bolt amps in an 03.
thanks
Old Apr 4, 2005 | 10:45 AM
LeX's Avatar
LeX
Nissan by Nature
can you not fit them under the seat? works in a 4th gen up to about 2.5height
Old Apr 4, 2005 | 10:50 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Are you running subs? Alot of members bolt them to the rear of the sub boxes. You could also make a false floor an not lose any trunk space, only the spare tire.
How big are the amps?
Old Apr 4, 2005 | 02:20 PM
TheBigDu's Avatar
Well, I know you said you don't want to take up trunk space, but...
Like a couple of others on here, I just built a tray to go under my carpet. Still have the spare tire accessible, and the amps are not visible from the trunk. I did not lose any area in the trunk, but I did lose about 4" of height. Anyway, its basically just two sheets of plywood, with a thicker one on top for more cargo support (the trunk is still usable). Then you can use some vertical bracing on the bottom (thinner) piece to support the top piece. You can space the bracing however you need it to fit a large amp. Right now, my tray is holding my ARC 4-channel, 2 Rainbow crossovers, and 2 distribution blocks. It's a little messy, but I haven't had time to clean up the wiring in the center passage yet. In the summer, I'll be throwing a sub amp on the right side, and moving that brace over. So it's a pretty flexible design. Here ya go:
Bottom tray with bracing:
Top tray lays on top of bracing (will probably fasten somehow in the future):
Carpet lays on top of top tray:
As you can see, it doesn't sit too high:
From inside the car:
Old Apr 4, 2005 | 04:13 PM
Pit5Bull's Avatar
@ Big Du...
Love what you did with your trunk, bro. I'll have to copy your idea, though...
Do you have something to prop up the false floor when you need to get to the spare?
Also, do you have the floor padded at the contact points where the floor makes contact with the metal parts of the trunk? I figure you'll need it in the event you add a sub to your system to prevent rattling. I built a "floor" in my 3rd Gen, but didn't think to do it the way you did. I like your idea MUCH better! Thanks for sharing
Old Apr 4, 2005 | 04:48 PM
TheBigDu's Avatar
Originally Posted by Pit5Bull
@ Big Du...
Do you have something to hold up the false floor when you need to get to the spare?
Thanks! I actually have to work on it a bit more, probably when I do get subs. I will have to add some kind of padding as you mentioned, and also get larger carpet to cover the gaps around the edges left by the stock carpet. I will probably also throw a piece of wood under the bottom sheet to hold the whole thing up for spare access. I'll also have to attach the top sheet to the braces on the bottom so it doesn't slide around, and I'll probably use hinges or something to still access the amps.
I should actually note that I got my idea from WildmanAL and studman.
Let me know if you have any questions.
-Brian
Old Apr 4, 2005 | 05:13 PM
MacAlert's Avatar
I HAD mine on the back of the back seats. The screws just ripped out so I'm thinking of making a template of the opening and cutting a piece of MDF then mount the amps to it. Have to see what Don has in mind when I go see him this weekend.
Old Apr 4, 2005 | 05:34 PM
nismo0604's Avatar
i screwed mine behind the seats
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Lowered_a33
Aug 24, 2015 04:35 AM
sc10692
Aug 9, 2015 09:37 AM
