Fosgate P3's Sealed or Vented
Alright i have a pair of fosgate p3's... i made a sealed enclosure (built to spec) and i have a vented enclosure...im debating which one to use... idealy which do u guys suggest.. the amp is a fosgate p8002 2 channel
by the was i listen to all types of music but mostly rock and rap
Ohh that's a hard one. Hmmm. I've dealth with Punch z's in both enclosures... and the fact that you listen to both rock and rap... makes it even harder.
I'd say the sealed. The p8002 amp is an AB if my memory recalls right. That with the vented box would pound your head off for Rap music, but you would loose a lot of SQ on the rock.
Plus, the fact the sealed is built to spec (for the subs I assume) Makes it a more natural choice.
If u have both enclosures definatly listen with the sub n both. I've known a lot of people that owned RF subs, and about 90% of the were n ported enclosures. Personally I have always owned a ported enclosure, sealed ones don't usually go deep enough for me.
properly designed sealed boxes go lower than ported boxes for ultra low extension. but this is usually only valuable for test tones or some movies (believe it or not blue crush goes to 10hz). IMO if your primary source of music is NOT rap do not go ported. its much easier to get rock,etc to sound good sealed.
for most subs (i say most because some subs still sound accurate in a ported application ), sealed will sound more accurate than ported boxes...perfect for quick bass beats found in rock, techno etc.
James92SE
142
01-02-2024 09:23 AM
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
