alternator dying? dimming has begun...
Old Apr 19, 2005 | 03:03 PM
anarchy57's Avatar
My set up is in my sig and my lights used to NEVER dim, and now they do, what can I do?
Old Apr 19, 2005 | 03:20 PM
CKOTuHA's Avatar
I have the same thing and my alternator was replaced less then a year ago.
I'm in the process of doing a retro kit in my car. Since HID kit uses 35w instead of 55w maybe that would help a little, but I'm not sure.
If you have a huge box, try to use a capacitor, maybe that will help. But do a reasearch on it since some people they they don't help. My friend has 3 JLs and his headlighs dimmed with a bass hit. Capacitor solved his problem.
Old Apr 19, 2005 | 04:05 PM
kpr10is's Avatar
Save your money and get a h/o alternator if you plan on keeping your car for a while
Old Apr 19, 2005 | 04:42 PM
anarchy57's Avatar
Dont know jack about alternators, how much would this h/o alternator run me?
Old Apr 19, 2005 | 04:45 PM
kpr10is's Avatar
the only one ive seen a couple other 4th genners get is from Can Am motors in tampa for 400ish, thats local to me though, im sure you can probably find something a little more local to you
Old Apr 19, 2005 | 04:50 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
About $300. Upgrade your big 3 and see if that helps..shold only run you about $30 for the 1/0 wire & terminals @ knukonceptz.
Old Apr 19, 2005 | 05:53 PM
'96MaxGLE's Avatar
The big 3 will definatly help. I don't know if it will totally elimnate the dimming, as i have yet to do this on my car, but i plan to very soon. A capacitor for each of your amps would probably help a lot also.
Old Apr 19, 2005 | 08:46 PM
Golden Ice's Avatar
a battery (even a motorcycle or lawnmower battery) located in the trunk will eliminate your dimming, but it will probably kill your stock output alt just as soon or sooner...my stock alt is flakey, and only charges when the car is first started for about the first 5-10 min then stops, no matter what the demand for power is..I run my amps off of a marine battery thats isolated from the starting battery, and I have a 1.5 amp onboard charger I plug in whenever I park just to keep the trunk battery charged..I don't drive the max much, so I don't worry about the extra hassle..
Old Apr 19, 2005 | 10:49 PM
'96MaxGLE's Avatar
Not true at all, not n my case anyway. I have a yellow top n my trunk, red top under the hood, no capacitors or anything yet cause i didn't think i would need them. My headlights will still dim along with my speedo cluster, with the music pumpin. I had my alt. checked and everything turned out fine with that. I think that doin the BIG 3 is gonna help me out a lot.
Old Apr 22, 2005 | 10:24 AM
Golden Ice's Avatar
well, when you go to install dual batteries, you ALWAYS ALWAYS double (or more) your grounding..i've got a 2ga to body ground, an 8ga common ground to alternator chassis, a 2ga common ground to battery ground, and numerous coax braid body grounds from the battery up front, an 8ga cable connecting the 2 battery grounds together, and a 2ga ground from rear battery to body...when I put the 2nd battery in, long before my alt died, ALL my dimming went away..and I already had several of those grounds in place before i put the 2nd battery in..i had 2 cables running to the trunk, 1 4ga for my sub amp and one 8ga I no longer used (from an old amp)..Ijust moved the 8ga to the grounds for the batteries, and used the 4ga for the pos. connection between the batteries.
TallTom
57
Oct 14, 2025 05:16 PM
gavin68
Sep 18, 2021 12:36 PM
maxima297
Sep 30, 2015 03:32 PM
