replacing HU and speakers - keeping bose sub
Old Apr 25, 2005 | 12:16 PM
dizmax96's Avatar
alright.. i read thru the faqs for the bose stuff.. now my question is.. do i still need to use the PAC-OEM1/RAD-UNV/AMP-NIS2 kit if im changing the door speakers as well?? i read somewhere on the .org that the rear speakers were quiet compared to the fronts after installed jus the HU with the wire harness kit. should i go ahead and wire the speakers to the HU directly? i still want to use the stock Bose amp and tweeters.. so should the harness kit be installed? thanks i would appreciate it
DiZ
oh yeah. the SWI-X.. anyone have a write up for this? wanna use the steering controls as well. thanks
Old Apr 25, 2005 | 08:50 PM
dizmax96's Avatar
anyone? can anyone answer this?
Old Apr 26, 2005 | 03:44 PM
danhaman's Avatar
If you aren't adding an aftermarket amp, you shouldn't need any kind of adaptor. I believe the one you are asking about is for going from speaker level to RCA inputs, which isn't required in this case. Are you going to run your speakers straight off the head unit?
dh
Old Apr 26, 2005 | 09:21 PM
dizmax96's Avatar
well thats wat i was thinkin.. if i upgrade my speakers should i run it straight to the HU? can i run it straight to the HU and still use the Bose sub?
Old Apr 27, 2005 | 02:49 AM
danhaman's Avatar
You'd have to send a signal to the bose amp as well as the new speakers from the new head unit [use studman's wire diagram to help you figure out which is which]. There's a possibility that the sub amp won't like getting power on it's input leads, but I doubt a new head unit will have more than 20 watts or so, so it might not matter. The same is possible for the other bose amp, if you plan on sending the signal to it prior to the speakers. Hopefully someone who has already done this will chime in and let you know.
dh
MikesChevelle
Nov 23, 2024 11:17 AM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
