Eclipse install
Old May 7, 2005 | 07:23 PM
CreativeDesignz's Avatar
Eclipse install
I have pretty decent experience when it comes to installign headunits. I am purchasing this http://forums.maxima.org/showthread....9&page=1&pp=30 on monday and would like to know how to ground the wire so that the screen stays open while driving. also i have 3 amps. 2 mono amps for my subs and one interior amp. which plugs should be used for the 2 sub amps because there is only one sub input on the back of the unit. thank you for any help that is given!!!
Old May 8, 2005 | 05:20 AM
1996blackmax's Avatar
On some amps you have the abililty to use one input (only one RCA needed to get full output), you may be able to do this, that is if the unit has 1 pair of sub outputs.
Does it really have only one RCA output, and not a pair?
Others also have the ability to pass the signal down stream through output RCA's. If your amp does both then your set . If not just use a splitter.
Old May 8, 2005 | 11:15 AM
my main consern is making the screen stay open when i put the car into drive. how do i go about that?
Old May 8, 2005 | 12:12 PM
The screen should stay open, otherwise you can't see track/radio info. The only thing is that if you are watching a movie, I think that it will not allow you to see it(the screen will remain out).
Old May 8, 2005 | 12:14 PM
yea i want to be able to watch a movie...thats the whole point im not gunna sit in my car with it off and watch a movie lol. there has to be a way to bypass this
Old May 8, 2005 | 01:09 PM
djfrestyl's Avatar
Suspension Yoda
ground the parking brake wire
Old May 8, 2005 | 02:41 PM
it doesnt vary from brand to brand? that just seems too easy lol
Old May 8, 2005 | 03:23 PM
PoLo's Avatar
2-Wheelin it...
eclipse...ground the parking brake wire....period....
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
