battery terminals
Old May 19, 2005 | 07:36 PM
danhaman's Avatar
battery terminals
I just looked at the battery on my I35 for the first time today, and noticed the clamp on the pos post has some type of plastic housing and a fuse. Is this for the bose system? Does the Maxima have the same? Anyone replace the factory housing with an aftermarket battery clamp?
Thanks,
dh
Old May 19, 2005 | 08:14 PM
seventy5impala's Avatar
although not an i35 my 2000 maxima has the similar set up....i need too connect a 4 gauge ring terminal somewhere... and im not sure how too go about it.... if i can just replace it all with an aftermarket one or not.....so im here waitin for a respone with ya danhaman
Old May 19, 2005 | 08:37 PM
Pearl96Max's Avatar
I tend to get a bit irritable
If you lift the cover theres a 10mm bolt that you can add a ring terminal to for adding an accesory line. Otherwise, yes you can change the terminal all together.
Old May 19, 2005 | 08:58 PM
thanks for the reply pearl, one more question, i tried too search but came up empty, wheres the best way too route a 4 gauge wire through a 2k maxima on the drivers side?.....figured no sense in making a new topic, this is battery terminal related :O
Old May 20, 2005 | 01:57 PM
DaBoxSE's Avatar
I ran my 4g wire through a grommet in the fender well.
Old May 20, 2005 | 05:42 PM
danhaman's Avatar
Do you know what the fuse is there for? I haven't had a good chance to really look at it, is it just a fused power distro for the stereo?
Thanks,
dh
Old May 20, 2005 | 06:15 PM
FormorAccordMan's Avatar
I highly doubt that there a special wire from the battery simply to power the stock stereo- even the stock bose. Today i rode in my friends 2001 i30 with bose and it truly was a laughable expereince I had to ask him to turn it down because the "sub" woudl not stop belching, It was truly a joke. Nissan should be ashamed of the max. i3o setup. Although his 2001 i30 sure did feel more powerful than my 99 max. ho hum
Old May 21, 2005 | 07:36 PM
danhaman's Avatar
That was just my guess, but now I'm curious. Most OEM 'specialty' manufacturers [Bose for infinity & acura, etc. . .] are still not great stereos, but to joe blow they sound just fine [witness the kudos to the I35 for it's stereo, from car reviews everywhere]. [It does sound much better than the Bose system in the Acura RSX, btw].
dh
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
