no power to amp
Old May 22, 2005 | 02:58 PM
jarrod91se's Avatar
no power to amp
i hooked up the system today and im not getting any power to my amp...everything is hooked up correctly, ive done many systems before. is it possible that my cap. is blown? the ground that im using is that little bracket on the right side of the trunk that holds the jack in place, i grinded it down on both sides....ive tried 3 different amps...the remote wire is hooked up correctly but no power still...please if you can help me that would be great thanks...
Old May 22, 2005 | 03:20 PM
CFC's Avatar
CFC
What do you mean you're not getting "any" power to the amp? Is there power on your cabling?
Do you have a multimeter? Just check to see if there's actually power there.
Check your fuse and check that the remote lead is working properly.
CFC
Old May 22, 2005 | 05:36 PM
AscendantMax's Avatar
yeah, check to see if theres power at the end of your cable. recheck fuses.
Old May 23, 2005 | 07:30 AM
PARALLEX's Avatar
the bracket that holds the jack will not work as a suffiencient grounding source.. i tried already...
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
