Amp feed back while accelerating
Old Jun 8, 2005 | 09:37 PM
Trevmister1610's Avatar
ok so today i installed my new amp and sub, but now im gettin a werid whine/feedback type noise, i havent used any type of rubber grovement in the fire wall, but i am gonna pick one up tommorw, will this solve my problem, or is it that i have cheap rca cables and they are picking it up from the power wire(the power and rca are one the same side of the car but i have heard many things sayin that it dosent matter, and just as many saying it does)
whats ur guys advice?
Old Jun 9, 2005 | 06:59 PM
kcidmil's Avatar
Switch the RCA and see. It really depends upon the cables you have. Mine work just fine... I have the twisted Streetwires. I haven't had any problems using them. Of course mine are setup in a truck. Much shorter area running together compared to a car.
Old Jun 9, 2005 | 07:49 PM
memphis_sktr's Avatar
I do know that the magnetic fields from the power wire could interfere with the rca cables. I have proven it with other scenarios, not car audio, and it is true. So if you can, after you switch out the rca's and it still does it, try to seperare the wires from each other. Like I always say though, I don't know everything, but I'm sure it is worth the try.
Old Jun 9, 2005 | 07:55 PM
jigga123's Avatar
Were are you amps grounded? How are they grounded and how long is the wire? This is the first thing I would check. Make sure you have a clena ground and scrape away any paint.
Old Jun 9, 2005 | 09:06 PM
traderfjp's Avatar
I like to ground my amps and HU together. You also can use lamp cord or a medum guage wire - you don't have to go crazy with the ground. I never have wine like you describe.
Old Jun 9, 2005 | 09:08 PM
AscendantMax's Avatar
check your grounds and make sure they're making good contact with the frame of the car.
Old Jun 9, 2005 | 09:47 PM
the amp is grounded in the spare whell tire weel, they are grounded with a bolt and screw, the ground wire lenght is 3 feet, tommorw moorning ill go make sure i have a good groud connection, and sand down the paint, if that dosent work ill switch the rcs cables to the opposite side of the car, and if that still dosent work ill get new rca cables, ill post back when i tell u what solved the problem
JRod28
Dec 29, 2023 09:56 PM
melteye
May 16, 2016 12:02 AM
boomerbrian
Nov 8, 2015 05:10 PM
Andy29
Aug 31, 2015 01:59 PM
homewrecker
Aug 24, 2015 08:56 PM
