crossover?
Old Jun 15, 2005 | 09:15 PM
kevdog's Avatar
crossover?
im replacing my frony speakers with some components and was wondering where a good spot for the x-overs would be there 4" wide,4 1/2" long and 1 1/2 "deep. this is for a 95 btw.
Old Jun 15, 2005 | 09:23 PM
kpr10is's Avatar
If the tweeters are going in the door, I mount them to the door frame itself with backstrap usually. If the tweeters are going in a pillar, I usually put em in the kick panel.
Old Jun 15, 2005 | 09:30 PM
kevdog's Avatar
i think im putting them in the door not to sure yet so the x-overs will fit inside the doorpanel?
Old Jun 15, 2005 | 09:37 PM
slickrick's Avatar
put them in ziplock bags or something of the sort...
Old Jun 15, 2005 | 09:49 PM
kevdog's Avatar
ill do that slick.
Old Jun 17, 2005 | 12:05 AM
ionpcs's Avatar
I mounted the crossovers in the doorpanel. I put screws into the panel and mounted the crossovers on those screws. Be careful though, with the first screw I put in I went slightly through the vinyl on the inside of the door. (luckily it was vinyl that was inside the map compartment and doesn't show)... in other words just don't screw too far into the panel if you choose to do it this way. Also I'd get some rubber washers or something to that effect, with deep bass my crossovers rattle a little in the doorpanel.
Old Jun 18, 2005 | 12:50 PM
erty67's Avatar
Decal Specialist
mine are in the door, mounted just above the speakers.
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
phatmax95
Nov 6, 2001 08:29 PM
Adam01GXE
Mar 22, 2001 03:45 PM
The_quorum
Mar 3, 2001 10:32 PM
