Help installing a crossover...(does it affect impendance)
Old Mar 3, 2001 | 01:47 PM
The_quorum's Avatar
I just got a 50w(RMS) x4 amp (4-8 ohms), 6.5 Rockford Fosgate 2-ways for all four main speakers, and a 10" dual voice coil sub.
I got the 4 main speakers and the amp installed just fine. Now what I'm trying to figure out how to hook up the sub to all of this. If I get a crossover, I'm assuming that I'd run the line from the head to the amp then into the crossover, then to the 6.5's out of the mid-range outputs, and the 10" from the low-output of the crossover. Does this affect the impendance (hooking up in essence 2 speakers to the same channel) (I'm not clear on this whole ohms thing), or do I not need to worry about this? Or am I completely off?
The head does not have a separate sub-woofer lead, and neither does the amp if that helps any.
What if I got a separate amp for the sub? how would I go about hooking that up then? HELP!
thanks for the info.
Old Mar 3, 2001 | 10:32 PM
Chunger's Avatar
My other car is a Hybrid
If your buying an active crossover (RCA PREAMPS) then no...
But I think you're trying to hook up the 10s with (another passive crossover)to the (passive)crossover box that came with your separates...
I think it may (not sure though.. any EE majors?!) It'll depend on the resistance of the subs too.
Have you thought of just getting a 3 way crossover since you're thinking of buying another set anyways? Make sure you keep the ohm rating same as separates...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
