Hazard light issue!!!
Old Jun 18, 2005 | 10:12 PM
SiCkBLaCKMaX99's Avatar
my turn signals are working with no problem but whe i press the hazard light button there is nothing i do not have any working hazards anyone know what this could be?? is there a fuse?? common problem? please help..
Old Jun 18, 2005 | 10:58 PM
memphis_sktr's Avatar
Did you check the wire harness in the back to make sure it is securely fastened? Just an idea.
Old Jun 20, 2005 | 03:05 PM
ok this may sound dumb to you but the wire harness in the back of what???
Old Jun 20, 2005 | 04:19 PM
When you take apart your console, the wire harness that is connected on the back of the hazard lights button.
Old Jun 20, 2005 | 04:31 PM
Also, I believe it is fuse 11. Check that one. And by the way, do you have a multimeter to help check the wires? It would help alot. If it isn't the fuse, it may be the wire (5r- orange/blue) from the fuse box to the switch (wire 3). Check that and see what you get.
Old Jun 20, 2005 | 04:47 PM
thanx a lot would you happen to know anything about my door light/speaker situation??
http://forums.maxima.org/showthread.php?t=407076
Old Jun 20, 2005 | 04:53 PM
Give me a couple minutes and I should be able to give you possible problems to look for.
Old Jun 20, 2005 | 05:04 PM
Another problem could be the switch itself.
Old Jun 20, 2005 | 05:06 PM
One more question, I am also going to assume that both the speaker and the tweeter is inop? And like maximeltman said, you could have cut or open wires. Check where the wires enter through the door for any cuts or exposed wires.
Old Jun 20, 2005 | 05:25 PM
About the door problem, I have come to the conclusion, depending on the outcome of both speakers and the light inop, definitely check wires going into the door. I found there to be no wires that are in common to one another. I looked on mine, and seen that there is tape on the outside of the bundle of wires. You need to take all the tape off; keeping in mind that you will either need to buy some more or use the same. You might be able to replace it with electrical tape, a couple of layers to make it environmentally enclosed. So tell me how everything goes. I can only help if you tell me everything you check. Do keep in mind, I am a certified 2m tech, and I don't know everything and don't pretend to. So I hope that I have helped you somewhat and good luck with finding the problem.
Old Jun 21, 2005 | 06:03 PM
Hey SiCkBLaCKMaX99, did you ever get your stuff fixed. Just wondering if I helped any.
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
AnsonJ
Jun 2, 2017 01:35 PM
doctorpullit
Aug 20, 2015 05:15 PM
