Mounting the Microvision??
Old Jun 29, 2005 | 01:30 PM
sean05's Avatar
well i jsut got my screen and it came with the screen, a remote, a casing around the monitor, a little silver piece and a mounting looking piece. How does this fit into the dash? How does it stay in there?
Old Jun 29, 2005 | 01:44 PM
raga55's Avatar
Im pretty sure theres a writeup floating around here if you look, but anyway, you use the silver thing to remove the casing around the monitor, then you disassemble the dash and the screen will sit in between the metal frame and the plastic trim panel, where the stock radio was, and will be held in there by the pressure from the frame and the trim piece. You might have to trim a little bit of plastic from the back of the monitor to make it sit flush but I would try putting it in first before cutting anything.
Old Jun 29, 2005 | 01:46 PM
sean05's Avatar
it is very very tight. I dont want to trim anything. SO its pretty much just pressure that holds it in?
Old Jun 29, 2005 | 02:01 PM
djmaverick's Avatar
Runs with scissors
I wouldn't really say pressure holds it in... (I have a Farenheit 7" in mine and I think it's almost exactly the same) when you take the stock HU out, the screen does not fit perfectly in the 2din opening. I made a little shelf for the bottom of the screen to sit on (using some plastic pieces and super glue) then make some small metal brackets to hold the screen from moving side to side and back into the dash. It actually is a lot easier than it sounds. When you take the HU out, you will see what I mean.
Old Jun 29, 2005 | 02:24 PM
Redmax's Avatar
Redlinemax Owner
you can call me at redlinemax.com 3012187336
Old Jun 29, 2005 | 02:28 PM
sean05's Avatar
Thanks man but i think i got it. Does it just squeeze in there? I mean there was no bracket to mount it to. It seems very tight in there. I dont think its going anywhere.
Old Jun 29, 2005 | 05:06 PM
raga55's Avatar
yea it just squeezes in it wont move unless something comes lose which prob wont happen
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
