Simple Amp/Sub Mounting
Old Aug 8, 2005 | 04:09 PM
Rotncarcas's Avatar
Ive skimmed this forum and havent found anything too useful, but I am looking to mount a smaller box and an amp in my trunk. I dont want to spend loads of time building a new trunk face, i just want to mount the box to the floor and the amp to a nearby wall.
What are some suggestions? In my 60second inspection I found metal floor and soft walls, so Im a little stuck on how to mount.
Old Aug 8, 2005 | 04:29 PM
djfrestyl's Avatar
Suspension Yoda
Mount the amp to the box (if it fits).
Use L brackets for the box.
Old Aug 8, 2005 | 04:31 PM
Rotncarcas's Avatar
Ive heard 600 times yea and nay for this method. I dont know if its a good idea. Under front seat a possibility?
In to the sheet metal?
Old Aug 8, 2005 | 05:20 PM
djfrestyl's Avatar
Suspension Yoda
Under driver or passenger seat is fine.
You can bolt it to the sheet metal, just be careful where you drill. What you can also do is create a false floor (trace your trunk mat, cut 1 inch smaller all the way around) and then you can just screw the box to that. This method will also help if that cardboard piece in your trunk is sagging.
Old Aug 8, 2005 | 05:27 PM
Rotncarcas's Avatar
plywood floor sounds like a plan, thanks
Old Aug 8, 2005 | 05:34 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Depending on the size of the amp, you could fit it under your seat as well.
Old Aug 8, 2005 | 08:51 PM
djfrestyl's Avatar
Suspension Yoda
No prob - let me know if you need any help. 1/4inch thickness is probably too thin and may warp/sag over time. 3/8inch minimum, I'd say.
Old Aug 8, 2005 | 08:58 PM
Rotncarcas's Avatar
I already bought the box from cartoys, hopefully its 1/4 inch
Old Aug 8, 2005 | 09:04 PM
djfrestyl's Avatar
Suspension Yoda
Box? I hope your subwoofer box is 3/4 inch MDF. I was talking about your false floor....
Old Aug 8, 2005 | 09:11 PM
Rotncarcas's Avatar
oh lol yeah wasnt really thinking about the numbers you gave. The box should be 3/4 mdf its just a standard cartoys box.
I work on construction sites so i can get pretty thick plywood for free
Old Aug 9, 2005 | 12:00 PM
max723's Avatar
dont bolt it to your box, it makes it a lot quicker to steal. i would bolt the box down and out the amp somewhere else bolted down.
Old Aug 9, 2005 | 05:44 PM
Rotncarcas's Avatar
yeah im gonna go with under the drivers seat for the amp, but brings up another point. Running the power wires from the left are easy enough, but any recommendations for a path for the rca wires running from the deck along the right side to the amp?
Old Aug 9, 2005 | 06:54 PM
RUN THEM TOGETHER. THERE WILL NOT BE ANY INTERFERENCE.
Old Aug 9, 2005 | 07:53 PM
djfrestyl's Avatar
Suspension Yoda
As long as you have half-way decent RCA's, you're in the clear.
Old Aug 9, 2005 | 08:01 PM
Rotncarcas's Avatar
Haha first time, and second time, that i have heard that. I might as well give it a try it will save hours.
Do I hear a third?
Old Aug 9, 2005 | 09:55 PM
my99maxisnice's Avatar
Sure, why not. Just make sure your ground is good. If I were you I'd put the amp in the trunk. I have my component amp under my seat and regret not putting it in the trunk.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
