wiring question
Old May 24, 2001 | 03:04 PM
White_lightning
i have an 98 infiniti I30 ( i know. its not a maxima. but close enough). I wanted to hard wire my
radar like i did in my previous trans am. but i have a problem. .. i cant find one damn opening
to pull the dash apart.. in my TA it was simple.. gaping holes everywhere.. the i30. NOT A
DMAN CHANCE>.... where can i get power from? and how do i get into the centerconsole
where the cig ligher is with out breaking the pannels?
also.. i wanted to do a stereo. but i cant see a grommit from the engine bay to the passanger
compartment. Do i need to drill a hole? or is there one i can use? thanks in advance
d.
Old May 24, 2001 | 11:42 PM
jashick's Avatar
d.
Does it run off 12VDC? If so, any chance you can cleanly run a wire to the fuse box found on the driver's side foot area?
For a stereo, you should be able to use the stock wire harness. If you want to add an amp, that's a different story.
Old May 25, 2001 | 06:41 AM
White_lightning
yeah.. it runs off 12V.. lemme check for the fuse box and see if i can get a wire there.. but then i need to find a ground this was much easier in my trans am.. gaping holes everywhere
Old May 25, 2001 | 08:25 AM
jashick's Avatar
Look for the ignition fuse and tap into the "ignition side" of it vs. the "battery side." Then the radar detector will power off when you turn off the engine...
Also, you can attach the ground to the chassis...so find a good place, scrape off some paint to expose the bare metal... and voila...
The Frye
Sep 2, 2021 11:03 AM
Maxie40
Sep 14, 2015 11:28 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
