The Big Three???
Old Aug 30, 2005 | 10:26 PM
seventy5impala's Avatar
The Big Three???
Hey all, i know this has been brought up and talked about but with the google search i couldnt find crap cept people mentioning it...., but im looking for some pics perhaps(or descriptions) of the big 3(is there more worth doing?) spots for a 2k maxima or similar too it(do i have too remove the stock air box, someone pointed out too me one, but he had an intake so i think thats why i didnt see it thus afternoon)....what guage wire too use, 4 all around or 8 in some spots? possible 2 or 0?....
Old Aug 31, 2005 | 07:22 AM
kpr10is's Avatar
You can use whatever gauge you want. Ive done it with both 4 and 0, 4 will probably be fine. Theres neg battery to ground, engine to ground, and positive alternator to positive battery. You probably will have to remove the airbox to ground the battery/chassis in the factory spot. The neg battery to ground and neg chassis to ground is one single wire, just follow it from the battery to the ground point then to the engine. Youll need a ratchet, extensions for it, and a 10mm and 12mm socket. Then look on your alternator for the black/red wire that comes straight off the 120A fuse from the battery. It will be under a little rubber cap that you have to pull back. If you find the wire and go to remove the nut on it to add your aftermarket wire, either take out the 120A fuse or take the battery terminal off so you dont blow that fuse. I usually leave the factory wire there, because the more the merrier.
Old Aug 31, 2005 | 10:37 AM
Wil's95SE's Avatar
我爱台湾
Here is the link. Maybe we should make this a sticky. Don can you help?
http://forum.sounddomain.com/ubb/ult...c;f=5;t=007801
Old Aug 31, 2005 | 12:04 PM
filtor1's Avatar
That is a great explination, however, I think we need a vehicle specific explanation with pics. I will be willing to take car of the 5th gen. Any takers for 3rd gen? 4th? If we organize and present it in an informative way, I am sure Don wouldn't mind making it a sticky. I will take the pics of mine and be ready with the explanation by this Friday.
Chris
Old Aug 31, 2005 | 12:27 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I put a link to that in the Deadening Sticky a looong time ago, brotha.
Old Aug 31, 2005 | 08:43 PM
jigga123's Avatar
Chris
I got pics of mine in a 3rd gen, PM me for it.
Old Aug 31, 2005 | 08:46 PM
filtor1's Avatar
Awesome jigga. See if you can put together a tutorial explaining what you did and the tools used. They will tend to be general but I would like to include other possibilities for tools and equipment. I will PM you with my home email when your done so I can get the pics and write-up.
Chris
Old Aug 31, 2005 | 08:57 PM
True, thanks alot kevin, and chris.... i look forward too seein the pictures.and 2marrow i think i might just take the air box off and see where it goes.... i might jsut get an intake just for the sheer fact id be able too ditch that HUGGE air box
Old Aug 31, 2005 | 08:59 PM
Wil's95SE's Avatar
我爱台湾
Thought so but for some reason unless I'm totally blind (which can happen at my age) I didn't see it anymore.
Old Aug 31, 2005 | 09:01 PM
Wil's95SE's Avatar
我爱台湾
Never mind. Had a slight "senior" moment.
Old Aug 31, 2005 | 09:13 PM
filtor1's Avatar
I have them daily.
Old Aug 31, 2005 | 09:14 PM
filtor1's Avatar
Having either a pop charger or PR CAI def makes the job easier. Why not, you have to remove the intake to do the big-3 anyway.
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
