New Audio installed + Question
Old Sep 9, 2005 | 09:25 PM
  #41
Kevlo911's Avatar
Kevlo for President
The hit MUCH harder than any 6.5 or 6x9 I have heard. I would say they sound better than most other brand small subs.
Old Sep 10, 2005 | 07:10 AM
  #42
nismos14's Avatar
§è~® f®ÈÄk
I just ordered a pair. The reviews on ICIX are insane. One guy has two in a slot ported box and he says with only 150 watts they sound better than his 15 did at 300 watts. Another guy had them hooked up inside his house or sound lab or something and they had to turn it down because it the bass was overpowering, and that was with just ONE! I am sold on these, I should get them pretty soon. After seeing your's and wanting to loose some weight in my car I decided to get these. Sold my 2 week old system and when I went to order these last night I COULDN'T! It said they were in the "pre-production phase" Well today I gave it another shot and I was able to order them I'm anxious now
Old Sep 10, 2005 | 07:13 AM
  #43
Kevlo911's Avatar
Kevlo for President
They freaking rock dude, I want to add some tweeters to the rear and make them look like components in the rear. These *****es sound better EVERY day. I think I need a bigger amp
What did you get? Dual VC 2 or 4ohm?
Old Sep 10, 2005 | 09:19 AM
  #44
nismos14's Avatar
§è~® f®ÈÄk
Well thats the thing, I don't know which ones they are sending, the site said "buy customize" So I clicked that, added two to my cart thinking that they will update and ask which ones I wanted, but that never happened. Either way, I'll make it work well. If they send me Dual 2 ohm I'll wire them to 4 ohm then run them in series to my bridged rear channels off my amp. If they send me dual 4ohm I'll wire them down to 2 ohms and use one on each channel of my amp's rear outputs. This way I'll get 220 rms to each one regardless of how I wire it.
I would suggest against the tweeters, you want you're soundstage to be up front. The tweeters, while adding some sound will not match well with those ED's. The Ed's frequency response is 20hz - 1000hz. You will have a huge gap between that and the 6000hz+ that you'll be running through the tweeters. If you really want to have something like that I'd suggest getting it to run as a 3 way setup with a small mid raneg then an additional tweeter.
BTW, Which ones did you get dvc 4ohm or dvc 2ohm?
Old Sep 10, 2005 | 09:35 AM
  #45
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
for your alt noise try grounding the rca.
If you note the rca should have a little wire running in the middle of it. What you do is strip that wire and secure one side to the chassis of the radio. ON the other end you strip it and create an L with the wire. You will put this L into the outer portion of the rca, then insert the rca into the amp. This cuts down on 90% of all radiated noise in a stereo, if you need a walk through on doing this hit me up and i can get more in depth. for you. Pretty easy and will show reults prior to adding the big three, i do this on every install and it works
Old Sep 10, 2005 | 09:39 AM
  #46
nismos14's Avatar
§è~® f®ÈÄk
Hmm thats weird, most rca's that I have used don't have any wire in the middle. The ones that do are remote wires
Old Sep 10, 2005 | 10:01 AM
  #47
nismos14's Avatar
§è~® f®ÈÄk
Hey Kev did you have any problems with moutning them in the stock locations? Some people on that forum have had trouble with the terminals sticking out when trying to mount these.
Old Sep 10, 2005 | 10:04 AM
  #48
Chocolate_Boi_1Der
nope, you can use it as a remote wire but in doing that your introducing current and running that right along your signal path which would increase your chances to pick up radiated noise all power and rcas should be kept seperate to eliminate any radiated noise .
Old Sep 10, 2005 | 10:08 AM
  #49
Chocolate_Boi_1Der
as well i cant find the dimensions on these, how deep are they? I may go with a set of those in the doors and move my components to a set of kicks ive been contemplating making
Old Sep 10, 2005 | 10:14 AM
  #50
nismos14's Avatar
§è~® f®ÈÄk
3.75 deep.
Running the wires together causing noise is a myth. As long as you use good quatlity wiring you can run them all together.
Old Sep 10, 2005 | 10:29 AM
  #51
nismos14's Avatar
§è~® f®ÈÄk
here's info on the ED's
http://edesignaudio.com/product.php?...=Specs&cur=USD
Old Sep 10, 2005 | 10:41 AM
  #52
AscendantMax's Avatar
3.75 deep.
i ran all my wires down one side for simplicity's sake...and have zero noises. just make sure all your grounds are good
Old Sep 10, 2005 | 11:04 AM
  #53
tedo007's Avatar
faster than you think
I had to drill new holes in the rear to make it work.
Kevlo911
Old Sep 10, 2005 | 11:08 AM
  #54
nismos14's Avatar
§è~® f®ÈÄk
Did you do that from underneath?
Old Sep 11, 2005 | 06:01 PM
  #55
Chocolate_Boi_1Der
good looking out on the link, and i look at it like this
its pretty much a standard for alternate routing, true its a personal choice; i use it due to if having worked in the past. +1 on your experience and glad it worked out, in situations where noise is radiated, he can use the methold listed above as that works
Old Sep 11, 2005 | 06:11 PM
  #56
nismos14's Avatar
§è~® f®ÈÄk
I don't think there's anything wrong with doing it, BUT its easier to run everything on one side, and IMO its piece of mind in having the good quality stuff right off the bat. (not saying that it would be worse quality stuff that would be used routing wires on opposites sides)
Old Sep 12, 2005 | 07:50 AM
  #57
Chocolate_Boi_1Der
lol igotcha
Old Sep 12, 2005 | 01:47 PM
  #58
Kevlo911's Avatar
Kevlo for President
Yeah, I was on my back in the trunk drilling.
Tip: Wear some glasses
Old Sep 12, 2005 | 07:02 PM
  #59
nismos14's Avatar
§è~® f®ÈÄk
Yea I'll wear my safety glasses, been there done that. (Screwing my subs in from underneath the trunk to keep them from sliding around hehe)
I ordered some 6.5 mdf rings, I'm gonna see if I can't mount them on top but bolt them down from underneath then just fit the speakers into the rings. That might be easier and probably help deaden the rattling a little bit. I'm afraid that I'll hit the bose grill with them like that though.....
Old Sep 12, 2005 | 07:52 PM
  #60
Kevlo911's Avatar
Kevlo for President
How tall are the rings? There seems to be a pretty good amount of clearence.
BTW, where did you get the rings from?
Old Sep 13, 2005 | 06:47 PM
  #61
nismos14's Avatar
§è~® f®ÈÄk
Ebay 19 bucks shipped. 3/4 inch tall rings, think they'll fit? I got my speakers today, looking forward to putting them in
Old Sep 13, 2005 | 06:50 PM
  #62
Kevlo911's Avatar
Kevlo for President
Yes, I think it will fit. I am about to order some
Old Sep 13, 2005 | 07:23 PM
  #63
nismos14's Avatar
§è~® f®ÈÄk
Here's who I got mine from
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
I'm worried about the terminals fitting through the rings though... hmm might have to modify them slightly.
Old Sep 13, 2005 | 07:25 PM
  #64
nismos14's Avatar
§è~® f®ÈÄk
Oh yah which voice coil config did you get?
Old Sep 15, 2005 | 07:10 AM
  #65
nismos14's Avatar
§è~® f®ÈÄk
Installing mine in about an hour, be back with results
Old Sep 15, 2005 | 01:02 PM
  #66
Kevlo911's Avatar
Kevlo for President
I have 2ohms Dual VC.
How are they?
Old Sep 15, 2005 | 04:27 PM
  #67
Maximeltman's Avatar
geeze I just watched that lil excursion video on the website, impressive
Old Sep 15, 2005 | 07:18 PM
  #68
nismos14's Avatar
§è~® f®ÈÄk
I have to say I am not impressed at the moment. I don't know what it is but I can barely even hear the midbass from them. My front stage completely drowns them out. I am going to exchange my dvc 2ohm ones for 4ohm ones to see if there was anything wrong with the speakers and to see if I can wire them to my amp running bridged instead of 2ohm mono. My gain is set all the way down and right now the way it is one of the speakers makes a popping sound at certain volumes which don't even seem that high. Especially considering my pioneer's handle that power level perfectly with no popping or distortion. I wonder if the one speaker just is defective or something.
Old Sep 15, 2005 | 07:25 PM
  #69
so they are indeed 2 ohm? hmm, might be defective or maybe the wiring is all jacked up?
Old Sep 15, 2005 | 07:34 PM
  #70
nismos14's Avatar
§è~® f®ÈÄk
I wired it up about 4 different times using different wires, different configurations and everything. I'm thinking the speaker is just defective. One of them sounds fine the other one is really the problem. I believe the 4 ohm version is tested to give 2.8 ohms and the 2 ohm is probably going to be somewhere along the lines of 1.5 ohms.
I figure with my amp (soundstream ega 4220) even with them wired to 4 ohms I still have enough head room to power them nicely, which is why I'm going to the DVC 4ohm version if they let me, otherwise I'll ask for a refund.
Old Sep 15, 2005 | 07:42 PM
  #71
Kevlo911's Avatar
Kevlo for President
That is wierd, the midbass from these drown out my front speaks.
Old Sep 15, 2005 | 07:57 PM
  #72
nismos14's Avatar
§è~® f®ÈÄk
We'll just have to wait and see then.... this sux, I was expecting better. A couple times I wired it the way I wanted it setup and it sounded awesome but the resistance was too low and my amp just shut off everytime the bass hit.
Old Sep 15, 2005 | 08:30 PM
  #73
Kevlo911's Avatar
Kevlo for President
Does your amp run stable at 2ohms?
That is similar to how I wired mine, but I have each speak to its own channel.
Also, the MDF ring worked right>?
Old Sep 15, 2005 | 08:42 PM
  #74
nismos14's Avatar
§è~® f®ÈÄk
Thats how mine are wired except one going to each channel for a ~4 ohm load to each. I got the rings after i had already installed the speakers, but from the looks of it they *SHOULD* fit just fine.
Old Sep 15, 2005 | 09:23 PM
  #75
filtor1's Avatar
Wow man. You could buy a sheet of 3/4"MDF for that and make 10 sets.
Old Sep 15, 2005 | 09:50 PM
  #76
nismos14's Avatar
§è~® f®ÈÄk
Yea but I don't have the tools to cut them and definately not the time and place to do it at.
Old Sep 15, 2005 | 10:03 PM
  #77
filtor1's Avatar
gotcha. Just thought I would mention it. I am glad they worked well.
Old Sep 16, 2005 | 06:07 AM
  #78
nismos14's Avatar
§è~® f®ÈÄk
Trust me I would have done it myself if I had the means, for me this was a cheaper route to take.
Old Sep 16, 2005 | 04:13 PM
  #79
nismos14's Avatar
§è~® f®ÈÄk
Returned the speakers today, going to try my luck with either Rockford Fosgate 4406 subs or Audiobahn AMD60Q
PH98I30
Jan 9, 2025 08:08 AM
vybz05
Dec 10, 2015 07:38 PM
mikekay
Aug 10, 2015 12:52 PM
Slamrod
Aug 10, 2015 12:33 PM
