New Audio installed + Question
Old Sep 5, 2005 | 11:58 AM
Kevlo911's Avatar
Kevlo for President
After 1.5 days of being sick and installing this new audio, I am finally done
Eclipse CD5435 - I still have not figured out all the features
Diamond Components M361 - They sound AWESOME. I love them. Only down side is the HUGE crossover
Old Sep 5, 2005 | 12:00 PM
Kevlo911's Avatar
Kevlo for President
Rear 6.5in SUBS. ID-700u - These sound awesome I love them
USC4065 AMP - This amp is awesome for the money. It only cost $140.
Now, what do I want the High and low pass filter set to for the front and rear?
Old Sep 5, 2005 | 12:01 PM
MannyNJ2k2max's Avatar
done? where's the dampening?
congrats BTW, new stuff is fun..
Old Sep 5, 2005 | 12:02 PM
Kevlo911's Avatar
Kevlo for President
Uhhh, it's only in the rear right now
Old Sep 5, 2005 | 12:05 PM
soooo, how about a review on those mini subs?
Old Sep 5, 2005 | 12:06 PM
danhaman's Avatar
I hear you about the diamond xovers, have you seen the new d9 comp xovers? They're the size of small amps. I'm not sure where you'd want to xover the 6.5" woofers, I'd try around 120Hz-140Hz, and adjust from there. US Acoustics has always put out a pretty economical amplifier, but it's still not an amp I would recommend [no offense intended at all].
dh
Old Sep 5, 2005 | 12:09 PM
Kevlo911's Avatar
Kevlo for President
I am going to let the subs break in a little bit. But right now they sound VERY nice. The boss responce is awesome. They are 2ohm Dual voice coil. I have NEVER seen a dual voice coil speaker in an 6.5" size. They can handle 150w RMS.
And as for the AMP, it was hard to find one with a better warrenty. It makes 65x4 at 4ohms at 12v. It makes 115x4 at 2ohms. It is underrated since I would be making more power at 14.4 volts. It also has a 3 year warrenty.
Old Sep 5, 2005 | 12:18 PM
Well Kevlo, glad you like it. My brother had cm3 components (braxially mounted) in his MX6 with a 125 x 2rms on it and its actually a very solid set. Nice tight, snappy and forceful midbass with that power- had no prob being xover at 80hz.
But the solidity of your doors, being its non -dampened will be the culprit for your xover freq due to resonance, airspace, power given....play around and set it as low as you can before it bottoms out at the highest level of volume you'd typically play it..
I really hope you consider, when you gather some more time/motivation, to dampen your doors/rear deck-I promise you you'll get the best from your investment.
Good luck
Old Sep 5, 2005 | 12:20 PM
Kevlo911's Avatar
Kevlo for President
I have done the rear deck, I need to do the doors, I need some more damping material
Old Sep 5, 2005 | 12:49 PM
ok...i didnt see any dampening underneath it(considering its an IB set up)
dont chincy out on pics...lol
Old Sep 5, 2005 | 12:51 PM
Kevlo911's Avatar
Kevlo for President
Oh, I only put it on the top of the deck. So I should put on bottom of deck to huh. Hmmmmmmm NEW PROJECT - Damping
Old Sep 5, 2005 | 12:58 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
What kind of wire is that? It looks to be KnuKonceptz aka teh sexy wire.
Old Sep 5, 2005 | 01:02 PM
Kevlo911's Avatar
Kevlo for President
Stinger 12guage wire
Old Sep 5, 2005 | 01:08 PM
those are some beefy 6.5's...are they mounted on a baffle?
are you trying to keep them conceiled under the OEM grills? if so maybe an mdf ring/plate underneath the rear deck can work nice solidifying them..
Old Sep 5, 2005 | 01:28 PM
Kevlo911's Avatar
Kevlo for President
Yeah I want to made MDF baffles for the front and rear. I just need a jigsaw.
It sounds really good right now, so it will only sound better with the MDF.
Old Sep 5, 2005 | 04:10 PM
danhaman's Avatar
Yeah, when I first saw the pic, I thought it was a beefy 10" sub, and that you were running 4 awg wire for the sub - talk about overkill. Of course reading helps a bunch.
dh
Old Sep 5, 2005 | 04:53 PM
maximariceboi's Avatar
nice....yo..wen u gona come down to install my 00vi? =D
Old Sep 6, 2005 | 04:37 PM
Kevlo911's Avatar
Kevlo for President
OMG, the damn alterantor whine. Where should I ground it? I tried the bolts on the back of the seat and I tried the strut bolt. It won't go away
Old Sep 6, 2005 | 08:17 PM
SEmy2K2go's Avatar
Go BUCKS!!!
The CD5435 is a great HU isn't it? I'm loving mine.
Old Sep 6, 2005 | 08:19 PM
Kevlo911's Avatar
Kevlo for President
Yes it is. I like it alot.
Where should I ground hte amp
Old Sep 6, 2005 | 08:33 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I'm not sure if you have a location like this in the 4th gens, but my grounding point is near the pass through area.
Old Sep 6, 2005 | 08:36 PM
2 Da Max's Avatar
dam bro looks sexy, how hard was it to cut that rear deck?
btw i grounded my amps under the rear seat, next to that big metal plate
o shiet i thought that was an 8 inch!! lol how does that go for?
Old Sep 7, 2005 | 08:15 AM
merovi's Avatar
i have the cd5425, a model below yours but i absolutly love it!
Old Sep 7, 2005 | 09:20 PM
nismos14's Avatar
§è~® f®ÈÄk
Looks good, how much did those 6.5 subs cost you?
Old Sep 7, 2005 | 10:16 PM
2 Da Max's Avatar
i asked him the same question, and you wont beleive the price....
Old Sep 7, 2005 | 10:35 PM
Maximeltman's Avatar
looks good.
ground it by either above pic or just drill a hole under the rear seat and spray over with rusto.
Old Sep 7, 2005 | 10:40 PM
nismos14's Avatar
§è~® f®ÈÄk
well what was the price lol?
Old Sep 8, 2005 | 07:21 AM
mendon99's Avatar
tastey wheat
wow are those free air subs? did you make your trunk all airtight? either way, makes me happy to know you're pleased with them, gives me another alternative for the future. the whine isn't nessecarily the ground... i have the same issue, everyone tells me to upgrade to the big 3., i still need to get a kit
and yea, baller here on the org has those diamond's all around, so i got a chance to hear them, they sound awesome.
Old Sep 8, 2005 | 01:05 PM
Kevlo911's Avatar
Kevlo for President
ED was having a special when I got the subs. $50 each 30bucks($80bucks original) off instantly.
Old Sep 8, 2005 | 10:26 PM
Poowill's Avatar
Diamond Components M361.....
These are soon to be installed on my max. Planning on flush mounting the tweeters to replace the stock tweeter grille. How are your setup?
I'm pumped to hear them, i'm pushing 75w to them with a 13w6v2 so i'm pumped to get it all set up. But was curious to see how you did the tweeters. Nice job on the setup btw
Old Sep 9, 2005 | 01:21 PM
Kevlo911's Avatar
Kevlo for President
The M361's are awesome man. The tweets are VERY nice and not too high, they don't hurt my ears.
Old Sep 9, 2005 | 02:05 PM
Kevlo911's Avatar
Kevlo for President
Okay, I sanded down my ground point so I know its good. What else could it be? The RCA's? I am using the ****ty RCA's that came with the WalMart amp kit.
http://cgi.ebay.com/STINGER-HYPER-SE...QQcmdZViewItem
http://cgi.ebay.com/KnuKonceptz-Mons...QQcmdZViewItem
Old Sep 9, 2005 | 02:31 PM
nismos14's Avatar
§è~® f®ÈÄk
I'd go with the knukonceptz wires they are prob better than the stinger.
Old Sep 9, 2005 | 02:34 PM
Kevlo911's Avatar
Kevlo for President
Do you know anywhere else I can get it cheaper?
Also anything else that could cause the whine? HU ground or anything? Or can the amp ground and RCA's only cause it?
Old Sep 9, 2005 | 03:08 PM
nismos14's Avatar
§è~® f®ÈÄk
It could be tons of things. Is the chassis of the amp completely isolated from any metal surfaces? The rca's could be picking up whine depending on how they were ran, there's alot of things that could cause it....
Old Sep 9, 2005 | 03:52 PM
KCMaxima98's Avatar
Good idea on the 6.5" subs in the back. I haven't seen too many people go with that type of setup. I wish I could hear it to see how it sounds.
I would think that an mdf ring would help a bunch on the front speakers since they are mounted to that stock plastic piece at the moment. The subs, however, are mounted direct to the metal on the rear deck though so it probably isn't worth taking the seats out again and redoing it. I'll bet they are nice and snug enough already.
Old Sep 9, 2005 | 03:56 PM
Kevlo911's Avatar
Kevlo for President
I have rubber spacers, but the bolts are touching metal so it is touching.
Old Sep 9, 2005 | 04:04 PM
nismos14's Avatar
§è~® f®ÈÄk
Try mounting a piece of MDF to that mounting location and re-mount the amp, it may just do the trick.
How do you like those ED 6.5's as far as bass response?
Old Sep 9, 2005 | 04:06 PM
Kevlo911's Avatar
Kevlo for President
Will do.
The ED's are WONDERFUL. They are very nice and clean. I need to add more damping and I will be set.
Old Sep 9, 2005 | 08:38 PM
nismos14's Avatar
§è~® f®ÈÄk
Is the bass response as good as say a small subwoofer? Or is it just as good as a 6.5 can be? I just sold my system tonight to some kid in town. Definately thinking long and hard about getting a pair of those.
