Mounting Frames for rear 6.5"
Old Sep 8, 2005 | 10:45 AM
farscaper's Avatar
I'm putting some basic Clarion 6.5" in the back. The metal mounting frames that come with, do not match up with the screw holes. They are pretty flimsy and twist if i try to drill them. I know that wood frames are better.
Should I cut some frames out of maybe 1/4 plywood?
Do I have to install the speakers from the top or can I install the new frames and speakers from underneath the back deck (through the trunk)?. If I upgrade or blow a speaker I hate taking the back deck apart.
Old Sep 8, 2005 | 03:09 PM
djfrestyl's Avatar
Suspension Yoda
do it from the top
and make 1/2 inch MDF baffles
Old Sep 8, 2005 | 03:42 PM
farscaper's Avatar
Won't the 1/2" MDF interfere with the installing of the rear deck?
Old Sep 9, 2005 | 08:18 AM
filtor1's Avatar
1/2" shouldn't bother the rear deck. Plenty of clearence. Another option is to get a few sq ft of deadener and cover the hole. Cut out the center and then drill new holes in the correct spots to match the mounting holes on the speakers. Another option would be the deadener and some self taping screws.
Old Sep 9, 2005 | 10:22 PM
farscaper's Avatar
Just finished an hour ago. Everything worked out great. Thanks djfrestyl & filtor1.
Old Sep 10, 2005 | 04:58 AM
filtor1's Avatar
Glad we could help...
Old Sep 10, 2005 | 06:58 AM
Kevlo911's Avatar
Kevlo for President
I will be buying some MDF this weekend. What should I use to cut it to get it the proper size for the front and rear baffles?
Old Sep 10, 2005 | 10:23 AM
farscaper's Avatar
I just used an inexpensive craftsman (sears) jig-saw. It goes through MDF like butter. If you only have a little bit to cut, even a hack-saw will have no trouble. If your building large boxes, I'd recommend a table saw or circular saw to get straighter lines.
Old Sep 10, 2005 | 10:45 AM
nismos14's Avatar
§è~® f®ÈÄk
While you're at it cut me some too
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
