went over bump now speakers don't play
Old Sep 19, 2005 | 11:11 AM
cardana24's Avatar
Blown
As the title says. I went over a bump in the road and the car hit pretty hard. When it hit the speakers stoped playing. However the sub will still play and that is it. Other than that I am getting no sound thru the speakers (all 4). What could this be? I replaced the deck thinking I had burned up the internal amp on the deck some how. With the new deck in it still does not play. The weird thing is that it will play for like 2 seconds everyonce in a while then the speakers will stop playing again. I am guessing I have pinched a wire somewhere, but where? Anyone good with this stuff I would appreciate any advice. Thanks.
-Carson
Old Sep 19, 2005 | 11:23 AM
Dohcser's Avatar
need more info,
Do you have the speakers hooked up to an AMP, it sounds like you do. If so check the Power, Ground, and Remote Wire to the amp.
Old Sep 19, 2005 | 11:49 AM
cardana24's Avatar
Blown
Originally Posted by Dohcser
need more info,
Sorry....only the sub is amped, everything else is running thru the deck. It would make more since to me if the interior speakers were amped. I do have a cheap walmart amp so I was concerned that some sort of crappy signal was coming back thru the RCA cables. Anyway speakers are not playing and they are hooked up to the deck.
Old Sep 19, 2005 | 12:15 PM
Dohcser's Avatar
It is very weird that all four would go out at once when they do not have a central point of contact. The only thing I could tell you is to check the impedance behind the deck to each speaker to ensure they are connected.
Old Sep 19, 2005 | 12:35 PM
cardana24's Avatar
Blown
I already did that.....nothing is really making since to me because if the ground was bad on the deck then it would not keep power, but it is playing CD's and everything, just nothing comes out of the speakers, but the sub is working.
Old Sep 19, 2005 | 01:08 PM
Dohcser's Avatar
I did not mention anything about the ground as you stated the deck is working. Check the continuity of the speaker wires.
Old Sep 19, 2005 | 01:26 PM
cardana24's Avatar
Blown
My brother just called and told me one of the terminals on a rear speaker is bent and when he pushes up on the speaker all the speakers turn on. So he just has a screwdriver wedged in there holding the speaker up a little and all the speakers are playing. So what is the problem? and why would one connection on a speaker affect all the others?
Old Sep 20, 2005 | 06:53 AM
Dohcser's Avatar
It sounds like that speaker lead was touching ground somehow. This is why I asked you to check the impedence of each speaker, if you did this, it would have told you right away that you literally had a "short circuit". Good thing you found it now, because this could blow your HU as there is very little resistance (i.e. < 4ohms) the HU would have ran hot and they smoked. Some HU's though have internal protection, buy mostly on the newer ones.
Old Sep 20, 2005 | 07:02 AM
cardana24's Avatar
Blown
I fixed it when my brother came over last night...somehow the one of the terminals on the speaker was bent up and was smashing down on the rear deck, so I pulled the terminal back out straight and plugged the line back in and everything works fine now.
Old Sep 20, 2005 | 12:12 PM
Batxel's Avatar
blah
It is not weird its called circuit protection most units have it. If one speaker is shorted they will all go out or at least they should. When the unit detects a short it turns off to protect itself. My old awia deck did it and so does my home stereo (Victor).
Old Sep 20, 2005 | 12:54 PM
Dohcser's Avatar
Re-read post 8.
Old Sep 20, 2005 | 03:08 PM
talisman311's Avatar
90% of the cars I work on with this problem, a terminal is shorted out. Easiest way to check is throw a meter on continuity, ground one probe and then put the other probe to each speaker.
Old Sep 20, 2005 | 05:38 PM
Batxel's Avatar
blah
Re-read post 8.
and post 8 tells me...?
Old Sep 21, 2005 | 06:17 AM
Dohcser's Avatar
Post 8 should tell you that I explained this to him what would cause it after he explained about the speaker terminal.
I believe you were trying to quote me when I first stated it was "weird". If you don't get it, never mind.
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
