What size power wire should i use?
Old Sep 22, 2005 | 10:42 AM
f550maranello2's Avatar
i have these 2 amps
http://www.rockfordfosgate.com/produ...h%20Amplifiers
and
right now i have a 4 awg to the distribution block and capacitor... and 8 gauage to the amps... is this too small?
it looks like this
http://www.cardomain.com/ride/2056133/2
Old Sep 22, 2005 | 10:49 AM
filtor1's Avatar
Nice spot for the Ipod.
With those amps, I would do 0gauge from the battery back and 4gauge from the dist. block to the amps. As well as 4gauge ground from each amp.
Chris
Old Sep 22, 2005 | 10:58 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Power wise you *could get away with the 4Awg. Although an upgrade could help....RF tends to like Alot of draw.
Old Sep 22, 2005 | 11:01 AM
hey Don what should i go with cuz i know its straining for power... and i need to replace the powerwire anyways
Old Sep 22, 2005 | 02:58 PM
MannyNJ2k2max's Avatar
You know your wiring isn't sufficient when one of your amps requests the same gauge size as the main power wire you are distributing from.
This advice has been given to you already...not long ago.
http://norcal.maxima.org/showthread.php?t=411712
http://norcal.maxima.org/showthread.php?t=387783
And to quote your own words, over 6 months ago...
Originally Posted by f550maranello2
thats what the spec sheet says... then the suggested wire size that is supposed to go in is 4 gauge
so why arent you at least giving the amp at least rated recommendation?
your only option is to go bigger....
Old Sep 22, 2005 | 05:44 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Power each amp with a 4ga into a distro block, distro block to battery with a 1/0.
OR
Do both a 1/0 to the battery.
Be done with it already.
Old Sep 22, 2005 | 05:47 PM
This will MOST DEF do the trick.
http://www.knukonceptz.com/productDe...prodID=KOL-AK0
Old Sep 22, 2005 | 07:30 PM
cool thanks guys for the help...
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
minsbang
Sep 11, 2015 08:48 PM
