question about our bose systems
Old Oct 13, 2005 | 02:57 PM
1NICEMAX's Avatar
does the head unit have a power out for subwoofers?
Old Oct 13, 2005 | 03:15 PM
f550maranello2's Avatar
no.........
Old Oct 13, 2005 | 07:25 PM
forevernicoles's Avatar
do you know what the max wattage is on the bose?
Old Oct 13, 2005 | 07:37 PM
1NICEMAX's Avatar
Originally Posted by f550maranello2
no.........
so what do you guys use?
Old Oct 16, 2005 | 01:20 PM
fishpony's Avatar
if your talking about a remote line, then u can use any wire that has 12V with the ignition on and none when the ignition is off. Just mess around till u find one.
Old Oct 16, 2005 | 01:49 PM
reygarcia's Avatar
Loved by MrGone longtime
what exactly are you trying to do? that kind of info is helpful to us so we can help you.
Old Oct 16, 2005 | 02:57 PM
1NICEMAX's Avatar
well I just wanted a simple set up. 1 or 2 10" subs and an amp using my bose HU and speakers. but I just found out that I need an audio line output converter to do this. correct?
Old Oct 17, 2005 | 10:24 AM
MarineMax's Avatar
Use the PAC AOEM-NIS2 adapter. Do a ebay search for "PAC AOEM-NIS2". This is what you need.
Old Oct 17, 2005 | 01:13 PM
1NICEMAX's Avatar
someone tells me i just need an audio line output converter aka hi/lo converter and tap them into my rear speakers.
Old Oct 17, 2005 | 01:50 PM
reygarcia's Avatar
yes, you will need a hi/lo converter to tap into the rear speakers. you can get this from best buy or circuit city.
Old Oct 17, 2005 | 06:22 PM
1NICEMAX's Avatar
ok so i need a hi/lo converter AND PAC AOEM-NIS2?
Old Oct 23, 2005 | 08:52 AM
NisAznMonk's Avatar
click here for more info on the adaptors you'll need
Old Oct 23, 2005 | 10:59 AM
fishpony's Avatar
if u really want to do it cheap just cut a pair of rca's and splice them into the rear speakers before the amp. The headunit is already sending out a low voltage signal so you dont need a hi/low converter.
MikesChevelle
Nov 23, 2024 11:17 AM
6spd4dsc
May 9, 2022 12:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
rhill4193
Aug 31, 2015 08:18 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
