Subs you guys could recommend if I want to run 4 subs in trunk WITHOUT SPL overkill?
Old Nov 3, 2005 | 03:12 PM
  #41
505max94se's Avatar
Originally Posted by AscendantMax
four RL-i' 10s. they work well in small enclosures, and doesn't take much power to get them pounding (and sounding accurate while doing it)
These 10's look really nice and if I remember correctly they're pretty cheap. I was thinking about getting some of them a while ago. Good luck on your choice.
Old Nov 3, 2005 | 03:18 PM
  #42
fishpony's Avatar
what you should do is instead of having 4 10's for sound quality is go with like 6-8 8" subs. I've been debating getting a few RE 8's. They don't require much airspace or power at all, only 175watts Rms. you would be able to make a smaller box and also you would be able to power 6 or 8 of them with one decent sized amp. Also i think there pretty cheap. Just throwing out ideas for ya.
Old Nov 3, 2005 | 03:48 PM
  #43
AscendantMax's Avatar
eh, six to eight 8's would require the same, if not more box volume than quad 10s...
i think it'll be a huge pain already trying to 'glass four 10s, let alone glassing eight 8's (unless Dan is up to the task that is...)
Old Nov 3, 2005 | 04:00 PM
  #44
fishpony's Avatar
hmm ok we'll take rockford fosgates P1's for example. One 10" per rockford specs requires .65cu ft. per sub. An 8" P1 only requires .25 cu ft. per sub. So...
4 10" = 2.6cu ft sealed
6 8" = 1.5cu ft
8 8" = 2.0 cu ft
10 8" = 2.5 cu ft.... and it's even smaller than 4 10's
if you need some help glassing i'll do it for ya!
Old Nov 3, 2005 | 04:29 PM
  #45
'96MaxGLE's Avatar
I can't believe no one has mentioned RE SE's...the RL-i's that were mentioned would b a good choice, also. I've heard lots of good things about them. You have a budget? What kinda power you looking to send to them?
Old Nov 3, 2005 | 05:01 PM
  #46
rteenie22's Avatar
jl audio w3v2
Old Nov 3, 2005 | 05:10 PM
  #47
kcidmil's Avatar
Why don't you buy my 4 Memphis M-Class subs... they had awesome SQ
Old Nov 3, 2005 | 05:46 PM
  #48
505max94se's Avatar
For name brand sq, go with jl w6v2, eclipse aluminum, alumapro, idq.
Old Nov 3, 2005 | 07:57 PM
  #49
Pearl96Max's Avatar
I tend to get a bit irritable
Originally Posted by BBOYSTEVIE
I've heard through the grapevine that the Genesis subs rawk too! Did you get my PM bout the Dyn MW 160's?
Yea I forgot all about it though. Ill check into it shortly, but why not the 170s?
Old Nov 3, 2005 | 09:19 PM
  #50
2 Da Max's Avatar
im curious what u did with the adire koda sub?
Old Nov 4, 2005 | 01:45 AM
  #51
BBOYSTEVIE's Avatar
Back from Hibernation
Midrange only in kickpanels. The 160's are more like 6's and the 170's more like 7's and with a beefier magnet/basket, right? I think the 160's will fit much easier, and like I said, they only need to go down to say 150 ish or so.
If I can swing it, I might get these drivers and the other ones I wrote you about together, pretty soon. Maybe I'll take closer measurements to see if I can get the 170's in there
Old Nov 4, 2005 | 09:42 AM
  #52
joebangaa's Avatar
forget the RE's, forget the idq's... but i'm still biased, i say id10v3s
Old Nov 4, 2005 | 12:32 PM
  #53
BBOYSTEVIE's Avatar
I'd take the IDQ's over the ID's anyday personally. I guess everyone has their preference. I have a good bit of experience with both of them. IDQ's sound less boomy than ID's and blend much easier w/ a solid front stage.
Old Nov 4, 2005 | 03:36 PM
  #54
Metal Maxima's Avatar
SHIFT_om nom nom nom
Still have it...I like to plan WAY in advannce, Avi.
YES. 6 EIGHTS FOR TEH WIN. I was just thinking how sweet this would look in a 'V' pattern...OOHHHH, BABY. Gettin' excited.
The new glassing project will likley be a year-long creation. It will cover the ENTIRE trunk.
Old Nov 4, 2005 | 03:55 PM
  #55
a "U" pattern would be more interesting imo
Old Nov 4, 2005 | 03:58 PM
  #56
Really? Whyso?
Old Nov 4, 2005 | 04:15 PM
  #57
well, seems like a lot of people have done the V pattern in their SUVs etc etc. I haven't seen anyone do a gradual curve with their fiberglass box and house 6 or more subs.
then again, mounting a sub on a curved surface would suck
Old Nov 4, 2005 | 04:29 PM
  #58
NisAznMonk's Avatar
four Peerless XLS 10" subs would fit in a 2ft³ sealed enclosure. That should give you plenty of room to go wild with your fiberglass idea
RE10's would be an awesome pick as well.
Old Nov 4, 2005 | 06:18 PM
  #59
KUBLKMAX's Avatar
have you considered Focal? Focal makes a 5 inch sub that rocks better than anything on the market. If you set up 6 or 8 of them that would be sick. Besides do you really need that many subs? that bass will hit so hard you won't be able to enjoy the music.
Old Nov 4, 2005 | 06:26 PM
  #60
focal makes some nice stuff, but as for it rocks "better than anything on the market"...have you heard every single sub on the market?
Old Nov 4, 2005 | 07:49 PM
  #61
djfrestyl's Avatar
Suspension Yoda
Subscribing because I'm selling my Kar 12 for a pair of 10's and can't decide which.
Old Nov 5, 2005 | 06:35 AM
  #62
Don, I'm going to be calling you later on today!!!
I'm thinkin'...
or
Old Nov 5, 2005 | 06:47 AM
  #63
nice choice on the amp there
Old Nov 5, 2005 | 07:26 AM
  #64
Yeah...I've got one last BIG mod before I am a poor man for quite some time (ring to save for, house, wedding...ugh, adult things. )
So it's either a phenomenal trunk system or an AE Body Kit...I am going to talk to Don and see what kind of $$$$ this will run me before I can conclude how realistic this will all be.
OH, and I would be able to run my FS ACTIVE...
Old Nov 5, 2005 | 07:58 AM
  #65
Pearl96Max's Avatar
I'm thinkin'...
or
No problem, Ill be around...
Old Nov 5, 2005 | 08:35 AM
  #66
ah definately talk to Don. there will be a new toy for me in the very near future.
Old Nov 5, 2005 | 08:40 AM
  #67
Just did. Looks like I am going to be running a 2500XKK with 4 Arc Audio 8s. I might change that to 2 Rainbow Profis, but then teh fiberglass fun is reduced.
Old Nov 5, 2005 | 08:44 AM
  #68
can't go wrong with arc
sick audio setup + your crazy amount of sound deadening = teh win!
Old Nov 5, 2005 | 08:56 AM
  #69
Thanks, man! Yeah, I sound deadened to the point where my sub is not even registering! I am super-excited to be doing another fiberglassing project. Especially now that I have some experience under my belt, this project is going to be SICK. I am going to start playing with some layouts, I am not sure if I want to put all four in the rear, or aim two towards the cabin, with one on each side of the trunk.
I am likley going to (at least try) to run two arches from the top corner of the back of the trunk to the front, and mount the amps in mid-air.
Ohhhhh, the possiblities...
Old Nov 5, 2005 | 09:48 AM
  #70
fishpony's Avatar
awesom decision goin with the 8's be ready for some major SQ. good luck with the fiberglass install, can't wait to see some pics of this.
Old Nov 6, 2005 | 07:52 AM
  #71
joebangaa's Avatar
sorry but idv3's > idqv2 period
Old Nov 6, 2005 | 09:21 AM
  #72
filtor1's Avatar
Just realized I haven't posted here. You can't go wrong with the Rainbows. But you know that. 4-8"s would be awesome. I really like the Alumapro 12"s that studman has as well. Just another option. And Arc all the way for juice!!!
Old Nov 7, 2005 | 07:07 AM
  #73
I would love to get some Alumapros or Rainbow Vanadiums, but I just don't have the dinero for 4 of them.
Thanks! It's going to be a peicemeal assembly, with 4 or 5 peices taking up the trunk. Once I am done the overhual I am going to start this project. I am going to cut a peice of wood and use that as the floor, then just build up from there...that will garuntee all of the peices sit flush. Lotsa research still yet to be done, namley how to fabricate arches...
Old Nov 7, 2005 | 08:03 AM
  #74
MannyNJ2k2max's Avatar
Dont sleep on the Arc 10's, half the cost of those above...if you heard my 2 12's on some rock/metal you'd definitly like'm....
How about Don let out some info and pricing for Arc's new line...the Arc Foose Designs line...
Old Nov 7, 2005 | 11:21 AM
  #75
kpr10is's Avatar
Not sure if Ive posted in this thread yet, but im subscribed for this
Old Nov 7, 2005 | 11:25 AM
  #76
I'm going to drop my Don's on the 19th...I'll see if he lets any good info go...
Old Nov 7, 2005 | 01:49 PM
  #77
BBOYSTEVIE's Avatar
No need to apologize because we disagree...The IDv3 is a great sub......well maybe because you're presenting your opinions on speakers as fact and not subjective. I am far from the only one that prefers the SQ of the IDQv2 to the ID (I include members of team Image Dynamics in that statement). Yeah the ID gets louder and sounds similar....some would call it more boomy Maybe we have different tases in bass (I'm a blender). The ID certainly wins on a pricepoint competition. Hard to beat for the price. But SQ of an IDQ? nah not imo (I stress that this is my opinion, not fact, and a valid opinion) good, but not as good IMO.
Think it's just me? Here ya go. http://forum.elitecaraudio.com/showt...threadid=94802 BTW, there are some VERY EXPERIENCED competitors giving their opinions here. Are their opinions factually wrong too?
Thats cool have your opinion. They're great subs, the ID's. Better period? Well, lets make sure the newbies reading this know this isn't fact and just one persons opinion.
I would say though, check out the Arc's as others are recommending. ID makes great subs
Old Nov 8, 2005 | 08:07 AM
  #78
filtor1's Avatar
These look pretty. No clue about performance though.
http://www.sonicelectronix.com/item_5743.html
Old Nov 8, 2005 | 12:35 PM
  #79
joebangaa's Avatar
i dunno i got to actually hear both IDs and IDQs recently and fell in love with the idv3s. idq's are sooo overdue for an update.. so is the idmax
Old Nov 8, 2005 | 02:03 PM
  #80
BBOYSTEVIE's Avatar
Yes they're nice subs. There are some out there that may like the ID sound over the IDQ. Listening experiences can be enclosure/car/rest of system dependant of course as well, but yes they're nice subs.
The IDQ's will be updated real soon and the powers that be are saying it will show improvement over the Arc v.2's, but of course, that is what Image would say. There are prototypes of an IDMAX v.4 out there, but I don't know how soon they're slated for release if at all. I'm fine with the IDMAX's as they are in the v.3 and of course I don't want to have to upgrade my subs to stay "current". I do think the v.3 was a good and yes noticeable improvement over v.2 and v.1.
Me though...what I'd REALLY like to see from ID is updated IDQ 8's, which haven't been sold for some time new. Some badassed midbass drivers. I've heard a lil rumor that they may resurface what was the IDQ 8 midbass driver in a neodonium inverted magnet 8 like the prototype Mic Wallace runs in his kicks. Think Illusion ND8's with much bigger *****. Talk of new products and the release of these products are a totally different thing, but DO count on updated IDQ's coming soon.
Or how bout rereleasing the ultimate SQ sub, the IDW's.
Oh, and I'd like to see them follow through with their golden unicorn, the IDONE. Not holding my breath, though If/when it comes out, I start saving for it.
Oh, and t-shirts too. I want Image dynamics t-shirts!
maxipower
Aug 21, 2015 11:10 AM
TMartinLVNV
Aug 16, 2015 01:48 PM
Turbobink
Aug 15, 2015 07:20 AM
Balkins
Aug 12, 2015 06:39 AM
Slamrod
Aug 10, 2015 12:33 PM
