Amp not powering up
Old Nov 9, 2005 | 09:05 PM
Sgibb's Avatar
Amp not powering up
So i wired up my amp and everything got it to power up for a second some how then it went off i checked all the fuses nothings burnt any suggestions?
Old Nov 9, 2005 | 09:06 PM
Sgibb's Avatar
ps someone said it coul dbe my speakers?
Old Nov 9, 2005 | 09:08 PM
nismos14's Avatar
§è~® f®ÈÄk
Take the fuse out of hte power wire and disconnect and reconnect everything then check anywhere that there is a wire connection to insure that it's connected properly.
Old Nov 9, 2005 | 09:12 PM
Sgibb's Avatar
its definetly connected right i check and re checked everything
Old Nov 10, 2005 | 06:42 AM
unrealii's Avatar
What about connecting just the power?
Old Nov 10, 2005 | 07:48 AM
nismos14's Avatar
§è~® f®ÈÄk
Did you check all the speaker connections?
Old Nov 10, 2005 | 08:03 AM
1996blackmax's Avatar
+1 on what nismos said. Speaker wires may be shorting out, and sending the amp into protection mode.
maxgtr2000's Avatar
KH3 by popular demand
If it has no lights on at all take a test light, turn radio on and check all the power terminals at the amp. Double check ground, it can slightly be loose and still give a signal that it is connected. When it is loose the amp may not power up. I though my amp went out on me, sent it to the dealer, it came back stating no problem. Double check the ground to the chassis and it was slightly loose, reconnected to a better spot, no problems.
Protect mode the amp puts out no sound.
Old Nov 13, 2005 | 09:43 PM
sodie14's Avatar
disconnect the speakers and see if the amp stays on or goes into protect right away...if it stays on, you can pretty much assume its a short in your speakers... any kind of over-draw from the speakers will put the amp into protection....
Old Nov 14, 2005 | 07:40 PM
DcMaN's Avatar
he said hes getting no power most likely its the remote turn on wire became unplugged
Old Nov 14, 2005 | 10:36 PM
kpr10is's Avatar
Multimeters are everyones friend. You can tell in a matter of seconds exactly what wires have power, ground, whether speaker wires are grounding out, the ohm load that each speaker is reading at the amp, etc.
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
