Profi or Profi Vanadium
Old Nov 21, 2005 | 10:22 PM
VTonmymind's Avatar
Mmm, fresh lobster
I've been mulling over component speakers for while now, first considering the Rainbow SLC's, then the Arc ACS's, but my thoughts have now graduated to the Rainbow Profi & Profi Vanadium lines. Nothing against the other speakers, (their price/performance ratio is very appealing) but I fear that after a while, I might get a hankerin to upgrade them, sooooo.....
How do I choose between these two?
Handling power seems to be the same (180 watts), so no diff there. I did notice that they are made of different compounds though, with the Profi using a natural fiber for the cone & tweeter vs. an aluminum compound for the Vanadiums. When I hear aluminum, I cringe a bit, thinking that it might lose some of it's warmth, but I can't imagine these would, but.....
In a nutshell: What is the difference in SQ between the two & which one would you recommend knowing that:
The price/performance ratio is still a factor, warm highs & strong punchy mids that compliment each other are prefered & I listen to bands like Dinosaur Jr./J Mascis + Fog. Disturbed, System Of A Down, Deftones, Rush, As I Lay Dying etc.
Thanks for any insight you can provide me with
Old Nov 22, 2005 | 07:53 AM
kpr10is's Avatar
My opinion? Go with the silk tweets and don't look back.
Old Nov 22, 2005 | 08:11 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Youve never heard the Titaniums.
Old Nov 22, 2005 | 08:17 AM
Pearl96Max's Avatar
Ive run both sets in my previous setups. I do prefer the Silk CAL27s, but only for my types of music for the most part. The Titanium CAL26s are surprisingly smooth and detailed for a metal dome.
With the difference in cones, Ive installed several sets of both and personally prefer the Vanadiums, but again My listening preferences. If your into rock,metal,etc the Profi set,but with the Titanium tweets would be an very nice setup. IMO.
Old Nov 22, 2005 | 11:44 AM
kpr10is's Avatar
I installed Steve's Vanadiums, and yes they sound awesomely amazing now that he has the Alpine 701 and RTA, but not many people go that extensively into tuning, and without it the tweeters were harsh. Not everyone can afford to have a DXE in every setup they run like you sir
PS...have you sent my 712t?
Old Nov 22, 2005 | 12:19 PM
Pearl96Max's Avatar
Blah blah blah.....
sent yesterday sir
Old Nov 22, 2005 | 12:34 PM
SC2K1's Avatar
I have the Profi Vans now and I do like them a lot. You will definitely need to devote some time to tuning them. The tweets can be very bright at first. On a side note my set of Profi's will be up for sale soon. I decided to go with a 3 way DLS set for my fronts. I haven't decided on a price yet but if you're interested PM me.
Old Nov 22, 2005 | 12:37 PM
Dasyce's Avatar
That being said, the DXE is one good investment.
Old Nov 22, 2005 | 02:19 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
That doesn't even do it justice. I had the privilidge to hear Don';s DXE in action...the flexibility of the DXE is beyond words, and I only got a glimpse of its capabilites. It's simply AMAZING.
Old Nov 22, 2005 | 03:43 PM
505max94se's Avatar
What so special about the dxe, it's just a fairly basic sound processor....
I have a set of pro van kick 3-ways. I don't like the tweeters and I hate the passive crossovers (the tweeter protection circuit will light up with less than 75 watts rms). Although the mids sound good.
I'll probably never buy another rainbow product unless I get rich and buy the reference series tweeters (supposedly better sounding than the scan speak revelator tweeters).
Old Nov 22, 2005 | 03:52 PM
MannyNJ2k2max's Avatar
I wouldn't say basic. Its arguably the finest piece of audiophile grade
analog xover engineering available, that is digitally controlled, super precise. Its simply for a different type of tuner, not one that works around factory locations in hopes of a center image, proper staging( basically needing the bandaid of time alignment).
Old Nov 23, 2005 | 06:31 PM
VTonmymind's Avatar
Mmm, fresh lobster
Since I'm just an audio simpleton, the DXE is not in my plans, so eliminating the Vanadiums seems like a logical choice seen as I won't have the goods to make them sound as good as they should.
Sounds like the Profi's are right up my alley. If I may ask though, so I can completely eliminate the Arc's from my train of thought, do the Cal 27's & the mids of the Profi's go above & beyond the Arc's mids & Cal 25 silks?
Also, what is the lowest RMS I can run the Cal 27's on without them going into protection mode? I've got an amp that I'd like to use for a while, but if it's insufficent, then perhaps I'll have to get a new amp before the speakers.
Thanks again.
Old Nov 23, 2005 | 06:53 PM
Thanks again.
For one...cal27's are out of the question...I may be one of maybe 3 other people in the whole US with the Power CS tweeters...They dont really stock the component set, as at $1300msrp its not a hot seller. And they dont sell individual drivers.
Two...the ARC ACS was base on the old pre '04 Professional set tweeter, in '04 that line was renamed the Profi line and new R&D brought forth the new
acoustic volume/chambered larger tweeters with lower Fs...
I think you mean the Cal26silks from the Profi line- excellent tweeters. Now the question is...standard midbass? Profi Phase plug midbass? or Kickbass? pick your poison...
I think for the cost of the Rainbow Profi(silk), it has little comparison to sets into the $1k range. The tweeter is that good.
Old Nov 23, 2005 | 07:46 PM
Make that four.
Old Nov 23, 2005 | 10:17 PM
Pearl96Max's Avatar
Originally Posted by Metal Maxima
Make that four.
No,No Manny has my old CAL27s from my AV6. The ones sitting here are the CAL26s. Titanium Vs Silk and about a good $100 or so more $$.
Old Nov 24, 2005 | 06:40 AM
VTonmymind's Avatar
Mmm, fresh lobster
For one...cal27's are out of the question....
Ooops, my bad, the Cal 26's, not the 27's. Thank you for the clarification.
I'm also glad you asked which mid I wanted, cause I was gonna ask what the differences were and which one would be best suit my musical tastes. I'm assuming I couldn't go wrong with a standard midbass setup, but am wildly curious what the other ones sound like.
Thanks again and hope y'all have a wonderful Thanksgiving!
Old Nov 24, 2005 | 07:04 AM
KUBLKMAX's Avatar
I would like to put my vote in for the Focal k2's. I have those but I want the eutopia's but not ready to send that much coin of speakers I figured 900 bucks for the K2's that I feel are some of the best reproducing speakers made. I have heard the rainbows and like those a lot but no one here sells them.
Old Nov 24, 2005 | 07:41 AM
VTonmymind's Avatar
Mmm, fresh lobster
If you're speaking of Rainbows, then Don does & at really good prices I might add. If your speaking of the Eutopia's, then ?
Old Nov 24, 2005 | 10:24 AM
Hrmmmm...
Old Nov 26, 2005 | 08:24 AM
VTonmymind's Avatar
Mmm, fresh lobster
Bumpin it up so I can get an idea what the other midbass's are like. (kick & phase) Hope ya'll don't mind.
Old Nov 26, 2005 | 09:54 AM
Kick bass has more robust midbass between 80-220hz and decent midrange.
Phase plug has decent midbass punch but very tight and snappy, very smooth and detailed midrange.
Standard driver is nice all around, very natural and transparent.
Old Nov 26, 2005 | 10:07 AM
VTonmymind's Avatar
Mmm, fresh lobster
thank you very much sir.
Pearl96Max
Aug 31, 2008 02:11 PM
BLACKonBLACK98
Dec 2, 2007 10:48 AM
2 MaXiMuS 4
Jun 26, 2006 10:51 AM
